350 casting numbers
Discussion in 'The Garage' started by adamforsythe, Apr 26, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Where are the casting numbers on a 350 engine?
    Adam
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    all gm sbc and bbc are driver side on lip of bellhousing of motor.
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Are they stamped into the block?
    Adam
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    The only numbers I am able to pull is 207.
    But these numbers on on the pass side and drivers side on the block just under the plugs.
    Adam
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    just as i said.
  6. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    They are directly behind the driver's side head on the bellhousing lip. They are not stamped, but cast into the block.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the back of engine on ledge, top part of bellhousing, the code is raised upwards liek that 207 is but not as big of numbers, scrub with wire brush or scrape with big screwdriver or something wipe with rag and there the numbers are
  8. diesel4me
    Jul 24, 2003
    17,567
    942
    Massachussetts
    casting #s VS model #'s
    The CASTING numbers are where Randy said,on the drivers side just behind the head--they get gunked up and are nearly impossible to see if the motor is in the vehicle...those numbers only tell you the cubic inch displacememt and approxamate year...there is a "clock" casted in on the other side that tells what day,month,and year it was made also...
    The "other" numbers are stamped in the block just in front of the passenger side head,its hidden behind the altenator,and are often not stamped in very good--you have to be careful cleaning them not to erase them if using a wire wheel or sandpaper!-those tell what year,what vehicle,HP,type of tranny it came mated too,etc..
    -I use carb cleaner and a brillo pad or 3m scotchbrite pad to clean them off--those "numbers" are actually letters,a code like CMD or something similar--any numbers next to the letter codes are part of the vehicles VIN # the motor came from...if that part of the block has NO letters or codes,either its hot,and someone ground them off--or the block was "decked" ,resurfaced in a surface grinder while being rebuilt..a factory replacement block might have the code "CE" stamped there(complete engine),and will usually have zero's or no other numbers next to it--(dealers are supposed to re-stamp the original numbers back in,but rarely do..) :crazy:
