350 casting # question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cocky, Jul 15, 2000.
  1. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    Can anybody tell me anything about an engine with the casting #3982888. I need to know if it is a 4 bolt main and what year it is and anything else that can be discovered with the casting #. Maybe i could call the a chevy dealership???
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  2. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    Are you absolutley sure you got all those digits right? One or two of those "8" could be a "3" or a "6" with some grime in it, making it look like an "8".
    Reason I´m asking is I can´t find that number at http://www.mortec.com/, but there are several # that looks a lot like it. F.ex: 3932388 and 3932386
    Andreas
    406cui of pure sh*t[​IMG]
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    please check it again I can't find it either. Also If its in a vehicle tell us which one. And look on the smooth "pad" behind where he head bolts to the block there are a series of numbers and letters, see if you can find the letters, most have 3 like "TYX" or something like that. JS
  4. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    what I meant to say is behind the alternator is the smooth pad. (sorry, just woke up, still hung over from going to the yankee game).
  5. cocky
    Feb 21, 2000
    88
    Northern Colorado
    Thanks for checking. I will double check the # but i can't do it until sunday or monday. This is a motor i might buy and the guy who owns it is out of town until then. He said it came out of a 79 truck.
    Richard
    1970 k5 Blazer
  6. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    I have the Chevy Small Block Casting number guide and that number is not in this book, check your number and repost it.
    Vincent Michels
    1978 Blazer
    Bruiser (Frost white/Black top/ Light Blue interior)
  7. Andreas
    188
    Sweden
    If it´s any of the two numbers I suggested, the 350 is a 69. The 3932386 has 4 bolt mains, while the 3932388 could either have 2 or 4 bolt mains. If the latter, your only solution is to pop the pan and check for yourself. Remember the 2 bolt mains is good up to 400hp, maybe even 500. So there´s no reason to ditch that engine if it´s in overall good shape, should you find out it´s a 2 bolt one. Downer would be the heads if they´re the original ones, as they´re pre-smog ones without hardened exhaust seats. Heads without hardened seats doesn´t like unleaded gas. Ok, I´m done now[​IMG]
    Andreas
  8. cocky
    Feb 21, 2000
    88
    Northern Colorado
    All right, here's the real casting #3932388. Also the pad behind the alternater says 19J204183V012OHV. Please tell me anything you can about this motor.
    Richard
    1970 k5 Blazer
  9. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    the first part of that sequence of digits is the vin # from the car the engine came out of. the last three are what motor it is like say---- OHV = 350cubes -180hp, 220ft lbs of torque, used in a 1/2 pickup, etc. etc. etc. I wish I had my numbers book on me.......JS
  10. cocky
    Feb 21, 2000
    88
    Northern Colorado
    Jimmy, thank you for that info. I had no idea that the vin for the car was on the engine too.
    I wonder if the DMV could run a vin for me and tell me what kind of car the motor came out of.
    Richard
    1970 k5 Blazer
  11. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    3932388 is a '69 - '76 350 block.
    HV was only used for a '65 Corvette 327. Could it be HU? That would be a '69 350, 255hp, 4bbl, originally used in a full size car.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  12. cocky
    Feb 21, 2000
    88
    Northern Colorado
    I just double checked and i'm positive it says HV. I wonder what motor it is.
    Richard
    1970 k5 Blazer
  13. Andreas
    188
    Sweden
    If you got the time, pop the valvecover on one cylinderhead and give us that number. It looks like the block number, about the same amount of digits. Of course it doesn´t tell you anything about the block, it´s just that I´m so d*mn curious[​IMG]
    Andreas
  14. Blazer1970
    1,600
    Old Mission, MI
    In '65, that would have been a small-journal 327, so that block would not have been made into a 350 using normal parts.
    Tim
  15. Andreas
    188
    Sweden
    Sorry Blazer1970, I changed my reply just 1 minute after I posted it, and that´s the post you answered to, right?
    Anyway folks, I talked about the 327 & 350 having the same bore-size. And that it could be a 327 made into a 350 by various rebuilding.
    Sorry again for the confusion[​IMG]
    Andreas
  16. Bruiser
    May 21, 2000
    320
    Caldwell,Idaho
    Cant find the casting number in my book , but found HV listed as a 65 corvette or a 69 chevy impala
    Vincent Michels
    1978 Blazer
  17. cocky
    Feb 21, 2000
    88
    Northern Colorado
    I popped the valve cover and got this #3932441. Is this the right one. Right under this # it said A179. In a separate place on the head it said GM with a 4 right beneath it.
    I'm really confused about what kind of motor i have just bought.
    Richard
    1970 k5 Blazer
  18. Andreas
    188
    Sweden
    Ok, those are 76cc 350 heads from 69-70 according to http://www.mortec.com/, which makes sense when the block # told you it was a 69-70.
    Andreas
  19. Blazer1970
    1,600
    Old Mission, MI
    A179 is the casting date code. January 17, 1969.
    V0120HV on your block means that the motor was assembled in Flint, MI, on January 20.
    Tim
  20. cocky
    Feb 21, 2000
    88
    Northern Colorado
    So does this mean i have a 350 out of a 1969 Impala?
    Richard
    1970 k5 Blazer
