350 crate motor 330hp help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Storm Trooper, Nov 24, 2000.
  1. Storm Trooper
    Nov 24, 2000
    4,640
    Hay guys, I,m putting a new chevy motor in my 87 K5 and am wondering if any of you put headers on your motors? The stock power stearing brackets mount to the manifold and I want to avoid this. Any Ideas?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The headers I've used in the past came with a spacer and an extra-long bolt to attach any brackets that mounted to the exhaust manifold. Some of the brackets may look like you don't really need them, but install them anyway. Usually the smaller brackets that go back to the manifold are there to cure a vibration problem. Install the bracket or the pump may vibrate itself to death.
    http://ThunderTruck.ColoradoK5.com
  3. Storm Trooper
    Nov 24, 2000
    4,640
    Thanks Harry, I did find the brackets I needed and If anyone else needs to know, if you don't want your AC anymore and need the simple brackets, you can use brackets off a 70 Chevelle/Nova etc. that DID NOT have AC. Been working on this truck for the past two months and should be firing it up realy soon !!!!! 330hp just waiting.....
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    when i had my landcrusier i put a ALAN GROVE bracket on the small block you can find those in or at street rod shops an mags.This work great for me. good luck.
    GAS ON IT!
  5. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    Hey Storm Trooper where did you get the engine from. I've been looking into one of those for my TransAm at
    http://www.sdpc2000.com/
    Topless73
