350 cylinder heads
Discussion in 'The Garage' started by 79cheyenne79, Apr 28, 2007.
  1. 79cheyenne79
    79cheyenne79 Registered Member
    Aug 14, 2005
    29
    maryland
    I have a cracked 1 that coolant is seeping out of. Should I buy both or can I get away with buying one side. And what problems if any would I encounter if I do just get one side?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Changing only the cracked head is ok as long as you match the casting numbers so that you end up with the same head. There are so many different heads available that you don't just want to throw any old head on there.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    1/2 the job now will cost you 2 x later. just get a matched set and get it done all at once.
