350 disection
Discussion in 'The Garage' started by chevy wrangler, Jan 5, 2007.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    well just a few minutes ago i went out side and started to disect the 350 that me and my dad pulled from the k-20 and swaped in a rebuilt 305 :(
    well the reason why we took it out was because it smoked and it smoked bad, when we first got it we imediately decided we needed a tune up. when we drained the oil all that came out was about a quart of goo, the PO said that the other PO put a new 350 in it . its a beat up farm truck and we beleve him, even more so now. well enough of that.LOL
    i first took of the valve covers and noticed the rockers were loose reallly loose and one of the rods was tight(stuck). so then i decided to take off the intake, the rod wasnt even in the lifter:eek1: . so this brings me to my question
    do u think that since the rockers were all screwed up, the engine smoked??? or is it that the piston seals are shot??
    it smokes white not black.
    here is a pic of the engine when we first got the truck,the PO spray paintedthe engine gold!!LOL
  2. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i tried search and cant come up with any thing!!!! can any one help me!!!!
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If the pushrod wasn't even in the lifter, then it should have had a miss on that cylinder. Shouldn't cause it to burn a major amount of oil though. You said all the rocker arms were loose, define loose for me. The reason I ask is because with the valve closed you should be able to move the rocker arms a little by hand. If the rockers were all very loose then it should have made alot of noise when running as well.
  4. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    a couple of them could move and i would be able to take the push rod out, they were all like really loose,
  5. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    That motor should have been tapping it's a$$ off, but yeah that's obviously too loose. I would still go through the engine though. Especially with the oil looking the way it did when you drained it.
  6. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    its out of the truck. i was just tearin it down to see what was causin it too smoke
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If the valve where the pushrod wasn't even in the lifter, then you could have a hole in the piston.
  8. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    hows that
