350 Engine Bracket Bolt Size?
Discussion in 'The Garage' started by Joe Kitzmiller, Mar 30, 2006.
  1. Joe Kitzmiller
    Joe Kitzmiller Registered Member
    Dec 20, 2004
    West Virginia
    What size (length, thread, diameter) bolt is needed for the engine mounting bracket on a 76' GM 350 block ? To make a long story short, I work out of town and rebuild my blazer on the weekends so i didn't get to check on what size is needed. Would like to know, so I can pick up bolts at Fastenal before going back home.
    After next weekend it's been a little over a year since starting to restore my 73' k5 and almost everything mechanically will be rebuilt or brand new. Thanks - Joe.
  2. 1-ton
    Apr 17, 2004
    Las Vegas, Nevada
    There are a lot of brackets on a chevy engine. I would say the most common bolt size for a bracket that bolts to the engine block would be a 3/8'x 1" course thread. Some accessories (like altenator P/S pump) use a metric bolt to bolt them to the bracket itself.
