350 engine: has fuel and spark, no start still..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Jun 15, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    got a 79 350 in a van that died while driving down a street yesterday and carb was not pumping fuel so i replaced fuel pump so now has fuel at carb and out the primary jets, i checked for spark first and it has good spark and wires routed in correct order and so im stumped, it turns over and over and over and not single hint of firing up as of yet even with spray down the carb, i havent flooded it by the amount i have sprayed in it but i think the owner dumped some fuel raw down it yesterday and other than being maybe flooded what the heck else could it be that may prevent it from firing up ??
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you have air
    you have fuel
    you have spark.
    do you have them at the right time? /forums/images/graemlins/thinking.gif
    Grant
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes, plus engine ran fine, it just plain died going down street, is driven everyday always ran good, he said it chugged and sputtered and died within a block, when i got to it it had no fuel at carb it was dry
    thanks for anything else
  4. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Check your timing chain to see if its broken. I had a Ferd ranger that did the exact same thing to me. Don't keep trying to crank it if it is broken. You will only cause more problems, like bent valves and the like.
    Kris
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Dump a cup of gas in the carb. Put the pedal to the metal and turn the key.
    If you've got spark and the fuel pump is working it has to start. Maybe check the fuel filter while you're at it.
    I really can't think of anything else, brother....... /forums/images/graemlins/thinking.gif /forums/images/graemlins/confused.gif
  6. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    I agree.. check to ensure the timing chain or cam didn't break... however if you got spark at the plug and the pump is pumping then no broken chain... if you got fuel pumping but the dist. isn't turning then the cam can be broken...Also check to ensure your getting enough fuel to the carb.. pull fuel line and place it in a soda bottle, disconnect power to dist and turn the engine over.. it should fill the bottle quickly...did you get the pump pushrod on the cam correctly.. I know mine fough me to the end last week trying to get it set right...
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sinc eits getting spark i can rule out cam and chain, cam runs the distributor, im unsure who all knows or realizes that ???
    i pulled spark plugs and a couple are dripping soaking wet.. as in i removed one and it dripped on floor mat....
    i put in dry ones and well i guess the cylinders didnt dry out quite enough,, plugs soaked again realy fast,, but engine almost fired
    i dunno how in the heck im gonna keep cylinders dry enough to quit soaking plugs,....
    im pissed at it and if it was my van id have blown the piece of crap up by now on purpose! !
    anyone know any good anti-fouling tricks ??
    thanks for anything
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh and two spark plug wires were burnt onto manifolds.. one all way through. he drives it pout of town everyday like that.
  9. Can Can
    15,552
    136
    Pull all the plugs and get some compressed air or a hair dryer(MAKE SURE IT'S SET ON "COOL") and blow some air into each sparkplug hole.
    Leave all the plugs out for an hour or so and try again.
    It sounds like the owner used a little too much gas when he tried to prime the carb, eh? /forums/images/graemlins/wink.gif /forums/images/graemlins/rolleyes.gif
  10. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is it a real strong spark? Ignition modual may have lost its strength. Sounds like a spark problem.It's there it just isn't strong enough to light the fuel.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its got a good strong spark, it flooded right back again when i put in some used dry plugs, tried to fire almost but quit cuz plugs soaked again,
    leaving engien sit with no plugs overnight for 14 hours right now and getting new plugs in the AM
    it is damn hard to get a wet engine to run again,..
  12. rcpilot
    Feb 22, 2002
    507
    Central Cali
    How soaked is the venturi's and throttle plates?? Could be the new pump is pumping the fuel past the needle seats...or you got something blocking the needle seats...if the carb bowls get over filled they'll dump into the bores...
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok have now ruled out fuel or spark problem, it seems ot be timing chain jump after all, moved the wires around the cap one spot each and well it wants to run but not right, but sooo much closer than before totally
    any comments or info or advice regarding cam timing that anyone wants to offer ?? whether it be about repairing this or whatever ?
    thanks!
  14. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Most likely your going to have to pull the timing cover to see how loose the chain is... if it is loose or you have broken off a gear tooth then it time to replace it...Don't know of any quick fixes...
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well definitely have not ruled out timing chain jumping a tooth, i have engine torn all way down to just the cover and even bolts out, so....
    please tell me any tricks on 350 chevy engines how to go about removing and installing timing chain cover without having to drop oil pan to do either thing to cover.
    ive heard of cutting the two ears off bottom of the cover to get them on without oil pan removal
    how true ?
    i tried that ionce on a 79 350 and it did not work out well at all, could not get bottom of cover on for the life of me no matter how much i trimmed and i even removed front bolts off pan..
    thanks
  16. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    2 or 3 part timing cover. from what i know in order to get a good seal you have to take them both off.
    sorry man.... maybe somebody else knows a good trick. if i have had to remove one it was because i was tering the engine down to the block or the front main or oil pan was leaking. so i had to ethier way.
    Grant
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well i removed cover and it came off alot easier than i thought it would, im just gonna use RVT sealer along bottom of cover at front of oil pan.
    thanks
  18. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I cannot imagine a timing chain jumping a tooth. yes yes Ive heard of it many times over the years but has anyone actually SEEN this? Its virtually impossible w/o severe damage to the chain/sprockets and the chain would have to be SOOOO loose that I dont think the engine would run well enough to drive in the first place. thats my $0.02
    mike
  19. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I have seen it, happened on my dads 350 in his burb. Didn't damage the gears what-so-ever, just the chain was super loose(original chain since 1977). But yes the motor didn't run perfect, but it did run pretty good, only felt like it needed a slight timing adjustment, although it was stretched out enough to jump 2 teeth at a time /forums/images/graemlins/shocked.gif
  20. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    how strong is the spark? the pickup coil might have taken a crap, so the spark is real low voltage...did the guy mess with the distributor? Could be 180 degrees out.
