350 heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tim_87, Apr 15, 2002.
  1. tim_87
    tim_87 1/2 ton status
    Feb 2, 2001
    101
    louisiana
    my motor is a 87 350 tbi. question is are the 350 vortech heads compatible with my 350. if i so any preference on year models. still trying to decided on heads or nave the valve seats replaced. the motor has 87,000 miles still runs good just has the chevy smoke when first cranked.. thanks!!!!!
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Vortec heads will fit, But you will have to buy the TBI intake with the vortec pattern from GM or have the heads drilled and tapped.
  3. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    please don't have the heads drilled and tapped. It will work but the intake runners on the vortec heads are taller then a standard sb. The angles of the runner from the carb to the heads are not as great when compare from the standard performer to my vortec performer. The height of the carb base on the vortec performer is almost the same height as the standard RPM performer.
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Getting the heads drilled and tapped is not the best way to handle the situation from "what I've heard" from gear heads.
