350 HO from gmgoodwrench
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Jul 17, 2002.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I am replacing my 86 305 with a the 350 Ho from gmgoodwrench. I have heard a number of times that the flexplate has to be change in some applications. My motor came with a one piece rear main seal, and I know that flexplates differ between the one piece and two piece rear main seal. IF my flexplate is alreay matched up to the one piece, will I still have to buy a different flexplate for the new motor being that it is a one piece too. And while I'm asking will the harmonic balancer be the same. Once again thanks for the help and info.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    It will most likely work. but I have heard that 86 motors were way weird in that regard.
    IMO it would not hurt to get a new flexplate. It is a good time to change it and with a new motor, I say go ahead. It doesnt cost a whole lot. It is cheap insurance. That new motor will have a lot of new found power.
    My .02,
    John
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    My 86 305 had a 2 peace main seal I had to but a new flywheel for a 1 peace
  4. Dunc03
    May 20, 2001
    157
    Tyler,Texas
    The only conformation I have on an 86 having a one piece is this site, so it is very possible that I'm wrong. I think I will get the flexplate now, that way I won't have the headache later, thanks for the info.
  5. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i'd say that the flexplate will work (since it is a 1 piece rear main seal). but, the harmonic balancer will not work!! i thought it was because of a balancing issue, but from what i've read, it's a timing mark issue, i think it's like 45 degrees off (something like that).
    http://www.sallee-chevrolet.com/Discus/board.html <-- good message board!!
    http://www.sallee-chevrolet.com/Discus/messages/653/2392.html?ThursdayMay3020021139am <-- not sure if this will work, but it's the thread about the timing marks that i was refering to. /forums/images/icons/wink.gif
  6. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Go to www.paceparts.com and look around. You can call the 800 number for the info you need. Check their prices for motors, too.
