350 motor rebuild help??
Discussion in 'The Garage' started by BCJimmy, Sep 7, 2005.
  1. BCJimmy
    BCJimmy Registered Member
    Feb 16, 2005
    6
    BC
    I am wanting to build a motor for my ride this winter and am wondering with my truck being a 1990 (computer controlled), do i need a specific core to rebuild or does it not matter?
  2. dyeager535
    26,980
    Heads are the main difference, but that block will use a one piece rear main, meaning the block, crank, and flexplate/flywheel are different than pre '87.(think that's the right year break)
    A good core would be a car block from '87+, roller cams in all of them.
    The difference for TBI is the head intake bolt pattern, and the fact that radical cams etc. require fine tuning through the ECM.
