350 or 305??
Discussion in 'The Garage' started by 87BrnRsd, Jun 8, 2005.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I have a motor but dont know if its a 350 or a 305. I pulled this number off the crank and was told that it could be determined with this number:
    4577
    If that doesnt determine it, I can get other numbers off of it. Can someone tell me if its a 305 or a 350? Thanks.
    -Harrison
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Where did ya get it , does it have an intake with a hole for a long tube up front ?
    Case being MORTEC says that crank number is for a 327 , forged so its a good piece for its time , just small journals , from mid 60's .
    get the block numbers of the rear , and the engine codes off the pad in the front .
    4577.......327.......forged..small journal....3.25" stroke
    http://www.mortec.com/cranks.htm
    http://www.nastyz28.com/sbcmenu.html says 1962-1967 327 crank . Although the stroke is the same on 307's , it wasn't put there by GM , so it could be a homemade engine or a 327 .
  3. 87BrnRsd
    Apr 21, 2003
    2,457
    Ok, I got a few more numbers.
    This one came off the passenger side of the block near the bottom of the bellhousing:
    I2 7 V
    And this one came off the passenger side of the block near the water pump:
    CE8 650 74
    There is one more number, but my brother has it with him. I can get it later tonight.
    -Harrison
  4. dyeager535
    26,980
    The suffix code is going to be the "best" code as it tells you pretty much everything the engine was when it was originally built. Casting numbers are ok too, you just get more from the suffix code.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Double check for a suffix code like Dorian mentioned .
    But I want to say that its an early 68 warranty engine , PROVIDED you got that on the pad on the pass side . Early 68 would still be small journal , and I think all small journal motors were forged , and thats a carryover crank. Or somone rebuilt it with that 62-67 crank . Too hard to tell until you double check all numbers .
    CE865074 looks like
    c : Chevy
    E: Engine
    8 : 1968
    65074 : sequence number for Tonowanda engine plant , which used 50000 to 79999
    This is from a search just now , but CE engines were common when cars were fun .
  6. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    couldn't you just measure the bore? 350 = 4" 305 = 3.75" (I think that is a 305 bore but not 100% sure on that)
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats too easy , it sounded as if there were heads on it .
    But seeingas how its a small journal crank , it couldn't be a 305 . And I have never heard of a small journal 307 , I think 307's were all large journal like the later 68 327's .
