350 or 383 or stock 454
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Jul 7, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    i am really confussed of what kinda engine i wanna buy this time.I wanted to get a stock 454 at first but then i had and offer on a 383 but know im kinda headin to a stock 350 but just changin the gears...i plan on running 38 inch swampers so i need alot of torgue im just really confussed can u guys help me out with this one what would u guys do ?...and if i get the 383 whats is the peak torgue u think i can get out of it ?
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Big block all the way, and never look back.
    ken
  3. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    but would a stock 454 put out enough power ??
    and how would the gas milage me on the motor ?
    <P ID="edit"><FONT SIZE=-1>Edited by wheelin247 on 07/07/01 01:01 AM (server time).</FONT></P>
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Sixes - across the board.
    So- whats your poision?
    I' like small blocks, 350s and defenetly 383s!- keep the weight down as much as possible. But you'd need gears to keep it iding under a load and add some torque to it -etc.
    But- Nothin' wrong with a big block, except the price and over-powering the drive train. So - upgrade drive train to the big stuff, and keep the gearing relitively hwy friendly- RPM wize.
    So - what is you poison. Throw you wallet at the engine, or throw it at the drive train? - Kinda sixes, I think.
    If you are planing on running 38" tires, You should up-grade the axles al least- so why not go for the full boat and go for the big block -- BUT.....
    Twiztid.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What gears do you have? If you want to run 38's you would nead to regear with any engine (around 4.56). 3.08's even with a built big block would suck with 38" tires.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree. Save some money on the motor if you have to, and get the right rear gear. I'd say 4.56s without O/D, 4.88s with OD. Try to get some stronger axles to put them in though first. My buddy ran 38s on 10 bolts with no major issues, now he runs 44s on 3/4 ton axles (10 bolt, 14 BFF). Just keep in mind you've got to be careful if you don't have the bulletproof stuff like it seems that everyone here (except me) has. And put a locker out back.
    Tim
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'd go gear first... definetly... then I really like the 383's for torque. You can make as much torque as a lot of big block combos if you play your cards right... but a BBC would also be sweet... buy both and try them out... give me the one you don't want [​IMG] LOL
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    454. Do it the first time and you will be glad you did.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  9. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    I say go with a 383(might be cause I have one and love it). Just one more opinion!
    Good Luck
    Rich
    Go heavy or Go home[​IMG]
  10. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    Allright thanks alot guys i have 1 ton running gear ready to get put on with 4:56's so axles arent really and issue right know but the way its sounding i think i might go with the 383 ....whats the most torgue u guys saw out of a 383 for decent money isnt it around like 415 ft lbs ?
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nah, the most I ever saw from a 383 was around 150 ft. lbs. of torque. [​IMG][​IMG] That ranks right up there with the 'ricers'! [​IMG] [​IMG] Get a 454 and be one of the 'big boys'!!! [​IMG] [​IMG]
  12. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Making torque in any engine depends on the cam first then the heads and a carb capable of flowing with the rest of the combo.
    For a 4x4 you are going to want the torqe down low.
    So a good cam and a duel plane intake is the best bet.
    With a 454 it is realy easy to build an engine that has a nice flat torque curve.
    That is it doesn't peak rapidly and then fall off the map.
    The end result being an engine that builds power across the entire RPM band and not just in the middle of it.
    A 454 can easily make 450 lb ft of torque at around 2000 rpms and build and hold that till the end.
    The down side is that BBC can get spendy real fast. But the same holds true for any engine that is built to last.
    my truck's not dirty, it's earth tone paint
  13. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I never knew there was such a question. YOU GOTTA GO WITH THE BIG BLOCK!!!!! I wish I had your problem. Good luck.
    <A target="_blank" HREF=http://www.thehungeronline.com>http://www.thehungeronline.com</A>
  14. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If you have the coin to do a bigblock swap it would be a good choice. A 383 is nice and is a good smallblock for torque. Alot depends on what you want to spend and what you will be doing with your rig.
    <font color=blue>Wayne<font color=blue>
  15. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Definitely big block. By the time you spend the money to get the torque you want from a built small block, you could have done a big block without so many mods necessary to twist it the way you want. However, the best reason is the torque curve; like this: <A target="_blank" HREF=http://community.webshots.com/photo/16047413/16991102rJFXEirQxP>http://community.webshots.com/photo/16047413/16991102rJFXEirQxP</A>.
    Robb
    '73 GMC Suburban - 502DFI
    <A target="_blank" HREF=http://community.webshots.com/user/robbrj>http://community.webshots.com/user/robbrj</A>
  16. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    My point exactly.
    And in my rig it never goes above 5K anyway.
    BTW I have two of them.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Desktop Dyno is awesome! I want to get it.
    My rig never cracks 4300 RPM. I don't see the need at all. Besides, it's so loud at 3000, I don't feel the need to push it any more.
    Tim
  18. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    when in doubt always GO BIG ,no replacement for cubic inch DISPLACEMENT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
