350 Qjet on 454
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 61Scout, Apr 7, 2001.
  1. 61Scout
    61Scout Registered Member
    May 11, 2000
    14
    Yakima, WA
    Can a quadrajet off a 350 be made to work on a 454? What do I need to change to make it run well?
    Thanks!
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I will soon swap a 454. I'm using an Edelbrock #1902 Quadrajet. It is supposed to work without any mods, just resetting idle mixture and speed. Worst case, I'll have to change primary jets or power valve spring. I might also have to change the secondary rods, but I doubt it.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have the Edelbrock Q-jet #1904 on my 85 K30. It works like a charm. Even though it was a little pricey, it was worth it.
  4. dyeager535
    26,978
    Yes. Primary metering rods/jets likely will have to be changed, and you can mess with the power piston spring as well. You'll have to know the specs on the 454 before making any kind of "guesses". You can also buy the doug roe book "rochester carburetors" to learn more about them. You can get it from Amazon.com
    You could throw it on the 454 and call it good. If it runs TOO lean you can burn your pistons, but thats an outside shot...usually won't run that lean.
    Dorian
