350 ram jet
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by K5Buckeye, Mar 27, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    Hey guys, what are your thoughts on the 350 ram jet that Chevy offers? Everytime I see the ad I daydream, "... ahh, fuel injection, no more cold starts." Is this setup ideal for our heavy trucks? This link has some details, http://www.sallee-chevrolet.com/ChevySmallBlockV8s/Ram_Jet_350.html
    Thanks.
    1972 K5
  2. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    The ramjet is a controversial setup. I believe that it isnt as efficient as the tpi etc because it lacks a lot of the equipment these setups use to take in outside information ie. o2 sensor and a few others etc. So it runs on the fuel map it has with no indication of whether it is running rich or not. I think this keeps it simple but probably not the best if you are looking for proper A/F ratio and peak performance. This is what I have read from other people though so if anybody has something to add or dispute please feel free.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Not sure here if the RamJet is closed-loop or not (missing O2 sensor, etc.), but if you have a manual transmission be warned that the RamJet uses the new (smaller) bolt pattern for the flywheel and you can't find a flywheel for a 12" clutch for that bolt pattern. Automatics don't have that problem, of course... Another potential problem might be in the calibration of the PROM if you have a manual transmission, as I believe the things are set up for automatics and to get the best possible operation you need to recalibrate for the stick.
    FWIW, I'm just a couple of months away from starting the actual hardware conversion for my modified TPI install. When I get it in and running, I will post about it.
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Do any of you know if the mounts for the Ram Jet are the same for a standerd 350?
  5. Roostr84
    Aug 19, 2000
    451
    NJ
    I believe they are the same mounts. I does use a conventional Small Block as its base.
  6. K5Buckeye
    Mar 5, 2001
    75
    WA
    Steve, looking forward to reading the write-up!
    1972 K5
