350 rebuild kit Qs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Mar 11, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Trying to figure out what rebuild kit to use on this motor. Casting number on back of block is 14093638 and the heads(center bolt style) are 14102193. Not sure if this was carb. or FI cause it is missing the intake. www.naparts.com lists several kits for the 87-up blocks (350-6 Carb Roller, 350-7 Roller, 350-8 Roller, 350 K Truck FI, 350 M Truck Carb) but I don't know which one I have. Does it make a difference on the internals? Wouldn't think Chevy would build that many different style engines. Planning on goin carb. and nothin special, just a simple rebuild.
    Is there another number on the block to be able to tell exactly what year and what it was originally installed in? Thanx Sam
  2. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    First, go to www.mortec.com/wmotor.htm and use the block number to see what year it is. Second, most of the internals were the same for almost 30 years on the 350. But, the differences could be the roller cam and lifter engines.
    Try this site for listing of available engine kits: http://engineparts.com/ceekonline/make.asp There is a online catalog of the kits that are offered.
  3. seslick77
    Jan 27, 2002
    220
    Ok, did all that, allready new it was a 87-95. Your site says: 2 or 4 bolt, Roller or flat tappetcam, 1 piece rear main seal. That still doesn't help me with what kit I'm supposed to get. Help is appreciated, Sam
  4. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
  5. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    What are you looking for in the kit? Do you want stock replacement parts or do you want some performance parts?
    You can customize the bill of materials for the kit anyway you want.
    What kit are you supposed to get?
