350 SMALL BLOCK ,POINTS THAT THE SPARK PLUG WIRES OF ON DISTRIBUTER
Discussion in 'The Garage' started by newbe73, Mar 28, 2002.
  1. newbe73
    newbe73 Registered Member
    Mar 14, 2002
    58
    SD
    can you give me a diagram or tell where the spark plug wires go from the distributor to the spark plugs. for a 350 small block on my 73 chevy blazer or tell me the firing order.
    i am waiting right now for a response because i am working on it right now. COME ON GUYS I REALY NEED YOUR HELP NOW SO DO NOT JUST PASS MY QUESTION TELL ME!
  2. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    I just left you an answer on the main board......
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    1 8 4 3 6 5 7 2 starting from the post above the dwell adj. window on the cap going clockwise.
  4. newbe73
    Mar 14, 2002
    58
    SD
    ok i sort of get it but it keeps misfiring but i know i am doing someting wrong here. here is kinda a diagram of want a am doing tell me what i am doing wrong
    this is the cylinders the way i # ordered them
    8 7
    6 5
    4 3
    2 1
    then this it the way i put them on the distributor
    __________6___5_____
    _______3_________7_____
    _______4_________2_____
    __________8___ 1_____
    tell me what i am doing wrong plz
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    That is all correct. Now just make sure you have the engine on the compression stroke and not the exhaust stroke. Sounds like you have the timing 180* off
  6. newbe73
    Mar 14, 2002
    58
    SD
    thanks alot everyone I got it to work!
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    You might want to remember this for the next time ( I found out the hard way ) try moving the wires on the cap one position counter clockwise Sometimes the dis gets set for the later years and if you try to do it like the book for a 73 it will not fire..I moved mine and it fired right up...mike
  8. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Mike, you took the words right outta my mouth. I'm glad to see you gots yours running after the steam clean.
  9. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Ya thanks for that help..And after that I pulled the dis.and put new intake and all that and would ya belive I did it again(as homer sounding as possible) duh and double duh..lol
