350 SWAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, Jan 22, 2001.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I just bought a 1995 350 for my 82 K5 and was wondering what bolted on from my 305. I plan to replace the water pump and add a double roller timing chain and replace the intake with an edelbrock performer. What else should I beaware of when swapping them out. I would appreciate any help possible ....Jason
    K5, Like a piece of heaven, right here on earth
  2. KENBARBOUR
    KENBARBOUR Registered Member
    Jan 14, 2001
    54
    I believe 86 and up have afew differences. They have different valve covers, a one piece rear main seal and an externally balanced cranshaft. therefore the flexplate (or flywheel) are different.
  3. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    If you're in the market for an Edelbrock Performer intake, I have one (Part No. 3701, fits Chevy small block). You might want to check to see if it will fit your new engine. Brand new, never used, still in the original box. If you're interested, let me know.
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    the 400 is the only externally balanced small block, the flywheel is different because of the one piece rear main in the 90. It has no flange like your 82 305, the 350 crank is just round where the flywheel bolts on with a dowl pin to put the flywheel on. the damper could also be different, compare the 305s to the 350s, see if they are the same, there were two different ones used. one damper is larger than the other, If you take the whole 350 from the 90 vehicle and put it in the 82 it should be a direct bolt in. What tranny do you have? if its the 700 be careful with your adjustments on the TV cable, if the cable is adjusted wrong and the 700 shifts too early you will cayse the trans to burn out fast.........js
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    i do have a 700r4 what do i need to adjust to make the right changes on tranny and do i need a new flywheel yes or no? thanks for the help....Jason
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    You will need an '86 or newer flex plate.
    The intake manifolds from the older engines will not bolt onto the newer ones. A few of the bolts are at different angles. I believe Edelbrock makes one that will fit, just be sure when ordering.
    The tv cable adjustment is critical and is outlined in the shop manual. If the tranny hasn't been rebuilt, plan on blowing it up, the early 700's are weak. They got better in mid '84, and then again around '86 or '87.
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
