350 t problems
Discussion in 'The Garage' started by nstarry, May 6, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    my van is going in and out of gear it will go in for a minute and then drop out you can get it up to overdrive then it holds is this the modulater or is it clogged any one know
    the gears are solid when it is in you can light up the tires
    mid 80s GM 1/2 ton 350/350t 2wd van
  2. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    check fluid level lately?
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    yep its full /forums/images/graemlins/thumb.gif
  4. motofool
    Apr 7, 2004
    361
    DFW tx
    ive heard a shift kit can solve those problems might of been only on th400's thou.
  5. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Sounds like there is an internal leak in the tranny that allows the pressure to drop enough to let it drop out of gear
    This happened to me with a 77 Gypsy van
    Its like it shifts into neutral when you stop , then when you hit the throttle it revs up and boom it drops into gear like you are doing a neutral drop /forums/images/graemlins/eek.gif
    This could be whats happening with your van /forums/images/graemlins/dunno.gif
  6. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    this is the other way it starts out then drops out then gos in then comes out and you can do that all the way threw the gears all the way to third then it will hold in third /forums/images/graemlins/dunno.gif
