350 TBI needs your help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bowtied, Jun 15, 2001.
  1. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    Hello againn all,
    I need your help in trying to figure out what is causing my 87 to run so poorly. As i said, it's an 87 350 TBI. It intermittently dies when sitting at a stop while tranny(TH350) is in drive. It will run fine until I stop and then the RPM's slowly fall until around 600-500 and then it dies.
    So far I've replaced:
    Plugs, Wires, Air Filter, Fuel Filter
    EGR Valve, EGR Control Solenoid, Idle Air Control, and the Oxygen sensor.
    It runs great when it's in higher throttle conditions. It just does'nt want to idle sometimes, actually most times, it will idle in gear every now and then, mostly for the first few minutes of driving.
    I know it could be a million things but if anyone can help I would greatly appreciate it!!!
    Thanks,
    Bowtied
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Check/replace all vacuum lines.
    Check/replace cap and rotor.
    Does it smoke (color?) when you restart?
    Dave
    "Visualize Whirled Peas"
  3. Bowtied
    May 21, 2001
    69
    NC
    Thanks for the reply.
    I did check for vacuum leaks, but have'nt yet messed with the cap and rotor (at least not that I can remember, did the tune up stuff last Nov.).
    And, no smoke on start up.
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Last Novemebr? You are probably due for a fuel filter again.
    Although mine loses power on the high-end when the fuel filter is plugged....
    Dave
    Don't Be Sexist - Broads Hate That
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    TH350 C???? Maybe electric lockup is locking up in idle??? I dunno, just a thought. What happens when you put it in Neutral? Same thing or heals up?
    <A target="_blank" HREF=http://fwp4x4.rockcrawler.com>http://fwp4x4.rockcrawler.com</A>
  6. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Look if the coolant temperture sensor is ok. It could be the problem when it`s faulty.
    good luck.
    Greetings from Amstelveen,
    River `90 K5, 350, TH700R4, NP241, "32, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The TPS may need adjusting also</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  8. Bowtied
    May 21, 2001
    69
    NC
    I had a friend suggest that also. Would this explain why it sometimes runs better when not quite up to operating temp?
    Thanks Again,
    Bowtied
  9. Bowtied
    May 21, 2001
    69
    NC
    biggray,
    How do you adjust it. Mine mounts on the opposite side of the throttle linkage to the throttle body and I think I can only remember two mount holes. Give me a heads up on the adjustment. I'm no stranger to a multi-meter if that helps.
    Thank you,
    Bowtied
