350 TBI stuff
Discussion in 'Engine | Tranny | T-case' started by big83chevy4x4, May 1, 2006.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    holley spread bore to TBI adapter part# 17-41
    $25
    350 TBI works great, still on running motor (TPS may be bad)
    $30
    350 TBI distributor, still in running motor
    $20
    TBI coil, less than a year old
    $10
    8747 computer from 89 1 ton C&C truck with 350
    $10
    7747 computer from 88 s10 blazer with 4.3
    $10
    3 MAP sensors 2 used 1 new (used maybe 3 months)
    $5 used
    $10 new
    single wire o2 sensor lengthened wire for easier installation used 1 month
    $10
    i have the TBI harness from the 88 s10 also, make offer.
    everything is still installed on motor.
    need to sell everything, need to fund reman qjet.
    its going on ebay in 2 weeks
  2. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Tbi
    So if I buy all this stuff what other pcs. do I need to put on my engine to get it running? Later J.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    knock sensor, ECS module, EGR position sensor, and probably a TPS.
    im not gonna lie, the reason we are selling it, not only because we are putting a carb on it, but we are tired of chasing the bugs. im not sure if the computer is fighting the cam or if its because the EGR is gone and the EGR position sensor is there, or if there is a bad sensor or what.
    i could sell you everything, but i would rather just sell what i know is good.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    What was this on? If I can use it on my 91 "V" truck I'll take it.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its on a 88 s10 blazer with a 350 in it.
    the base is from the 88 s10 4.3, i have a base from a 88-92 305 truck that ill throw in if you want that. the only difference is the 4.3 has another vacuum port on the front, ported i think, and the part where the cables attach to is shaped different, looks like the TV cable stud is off just a little bit compared to the other one, other than that they are identicle.
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Sorry but I think I'll pass. I'm looking for a spare tb just like the one on my truck for a spare.
    Thanks anyway! :thumb:
