350 ticking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jan 15, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I noticed a small ticking sound today at idle and when i accelerate. Is this something with the valve lash?
    90K5
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> It may be something as simple as an exhaust leak. Have you checked that ?</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    No...maybe I should
    90K5
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like a exhaust leak to me to
    s.smith 77blazer lookin 4 mud
  5. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    everytime i hear ticking paranoia sets in, and i usually end up discovering its the exhaust. however, once it was the rocker and a little adjustment set them straight.
    Knife.
    knife.coloradok5.com
  6. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    I get a ticking whenever my oil gets low and I drive at high speeds. It'll quit once the engine cools down or when I add oil. Its not quiet, its pretty loud. My guess is its a lifter getting stuck.
    I had to replace my passenger side exhaust manifold gasket because of an exhaust leak. It was quieter than my current tick, but definitely noticable. Boy was that a pain in the ass to change! Bolt busted off!
  7. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    305. I just started having some ticking coming from the left side. It's on first start up. Then once warm it stops. I too was wondering if it is an exhaust leak that stops once the exhaust manifold warms up. Sound right?
  8. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    I had an exhaust leak that was just the way you descibed -- a ticking when cold and it goes away when the engine warms up. I just took my passenger side exhaust manifold off to replace the gasket (which I thought was leaking) and discovered underneath one of the heat shields that the manifold was cracked. I talked to a buddy of mine and he says this is a common problem on these trucks. I was going to get a junkyard part, but he said it will probably crack too, that is, if I can find one that's not already cracked. So I ordered a set of Edlebrock headers for $267.00. Should be rolling again Tuesday or Wednesday...
  9. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    ok,,,mine does not tick when cold, but ticks when warm!!! i did however buy new fel-pro manifold gaskets and they will go on tommorrow, so i guess ill see
    AIRBORNE!!
  10. chevydude
    chevydude Registered Member
    Dec 10, 2000
    38
    mat-su valley alaska
    whenever i start getting strange noises from an engine i use a piece of pipe to listen with,it works just like a stethoscope
    put it right on the valve cover and move it slowly you will easily be able to tell if its a lifter also listen to your fuel pump sometimes they will tick also
    marcus
  11. Eric
    Eric Registered Member
    Mar 21, 2000
    86
    Just pulled my 305 and found that the annoying ticking was indeed an exhaust leak at the last exhuast manifold bold towards the firewall. CHECK for exhuast leakage!!
    One eyed super fly- watch out!
    86 K5 Blazer
  12. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    hey that long rod aint no joke...one time i had a water pump going out, but it sounded like a main bearing was going out..i immiadetly (sp?) started freaking out, thinking where im going to get an engine, cost, and everything else involved. my dad leisurely strolled out to the garage grabbed a long screwdriver, put it on the alternator, the belt tensioner, then the water pump.. he handed it to me and said "go get a water pump" he is not even a mechanic!!!
    AIRBORNE!!
  13. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I have a slight, faint tick at start up when cold. But as it gets warm it goes away. I was told by a chevy mech that it was more than likely what is know as piston slap. Where the pins in the pistons are slightly warn letting them slap the cylinder walls untill teh heat causes tehm to swell, then the slop goes away and no more tick.
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
