350 timing
Discussion in 'The Garage' started by johnathan, Feb 11, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I swaped in a 350 in place of my 305 where should my timing be? the motor is stock
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    There are a few variables that affect your static timing ( like altitude, octain of your fuel, compression ratio to name some ) Start at around 4 to 8 deg. BTDC and take it from there.
  3. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Chiltons list most years at 8* btdc. Plus 1* per thousand feet of elevation.
  4. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    thanks I'm runnin 4 btdc cause thats what the 305 called for I'm gonna go with 8 thanks
