350 timing???
Discussion in 'The Garage' started by incognyto, Nov 14, 2002.
  1. incognyto
    incognyto Registered Member
    Nov 5, 2002
    Just put a 350 outa a rolled 86 4x4 chev truck, into my wrangler, everything's better except acceleration when you matt it. I don't know what the timing should be and my Hayne's manual say's to refer to the VECI label. Problem is this is the second 350 that's been in the truck and the VECI is for a 5.0?? also is there better degrees to use when lookin for performance vs. economy???
    Thanks in advance. /forums/images/graemlins/truck.gif /forums/images/graemlins/angryfire.gif
  2. jtpepper
    jtpepper Registered Member
    Jun 4, 2002
    Around 10 degrees b.t.d.c. should work fine.Make sure you disconnect the vacuum advance and plug the vacuum port before setting the timing.If this dosn't work,pull the vacuum advance side towards the front of the engine till it's facing number 2 cylinder then drive it and slowly work it back till it feels good.This will work if the distributor was stabbed correctly.Good luck and GOD Bless,jtpepper
