350 to 454 in 78...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jun 14, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I post this in burban room as well. We are swappinh in a 454 for a tired old 350 in a 78 burb. Any hints, tips, list of mods, etc etc etc. (mounts, brackets, clearances, etc)
    And are the engine comparments between a blazer and a burban in 78 fairly close to the same aas far as size if not identical?
    Steve Watson for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    You're screwed, lol. Have fun. Man, I'm just kidding ya. I never got those headers on. My fuel pump went south on my way to the exhaust shop! What a whore! Anyway, I gotta get some food before work.
    -BuSH
    I'm a dislectic agnostic. I believe in a higher being, his name is DOG. [​IMG]
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Dude you have worse luck than I do, and thats BAD!!!!
    Steve Fox for President, 2004.
  4. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    even worse, I was stranded 1 street away fomr my house. How shitty!
    -BuSH
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    It will fit just fine. Make sure you have all the brackts for the big block.
    74 Blazer
    Zepplin
    Check out my Blazer <A target="_blank" HREF=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</A>
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Energy Motor Mounts, BBC acc. brackets, larger radiator and if you go with headers, stay away from the BBC Dynomax headers. They'll hit the shackles/driveshaft. Doug Thorleys fit great but are expensive. Distributers are the same.
    Shawn
    87 K5
    few mods [​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    So will the 454 motor mounts bolt up to the frame correctly? Looks very close, just eyeballing it.
    And Im assuming that the TH400 will bolt straigt up. But with the bigger block, is it going to move the tranny/t-case combo back a little further? IE will we have to move the crossmember back a little?
  8. Shawn
    1,753
    5
    5280'
    Yes, it will bolt to the frame just fine
    Looks very close, just eyeballing it. And Im assuming that the TH400 will bolt straigt up.
    yes, no problem there.
    nope
    nope
    Gotta love GM!
    Shawn
    87 K5
    few mods [​IMG]
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Shawn, you rock man. Thanks. After we get this all in and running hes going to remove the body and lengthen the frame by 5 inches, ( I dont think he needs to), then he swapping out the body with a 40's panel truck body. Home made grave digger.
