$350 to rebuild a D44. Good price?
Discussion in 'The Garage' started by mtrdrms, Jun 24, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    My front axle seals are leaking and I dont feel like getting into that project. A local shop gave me a quote of 350-400 depending on parts that are bad. Good deal or shop around?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Just for seals i would say that is a little high. I can do that job in a little over an hour, and the parts can't be much more than $50 if even that
  3. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    seems reasonable parts are cheap its the labor involved and at $75 an hour $350-400 doesn't seem outragous. If you want to do the labor you would only be in the project for under $100
  4. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    They're not terrible to replace... I just did my front and rear end. Took about... 2 hours to fully unassemble, replace those, the bearings, and other crap, then reassemble them. I'd say it's worth saving the money to do yourself. Then you could spend it on other mods :D
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Never Give Up
    If you have a floor jack then do it yourself its not as bad as you think, any of the tools you don't have you are going to need eventually so take a break from this beast and hit it again tomorrow, remember what we do is for fun and to be original, I tackled rebuilding a T350 tranny before I touched regearing my axles because I read so much about how hard it was to get gears set up right, get a good understanding of what you are doing and it is not that bad
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    On one hand I think that's a reasonable price for a shop to do the job.............on the other hand I think you are getting bent over backwards because it's relatively easy to do at home..............pick your poison.
  7. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    If that includes the inner seals for the inner shafts than that would be a good price...they are a bugger to get in/out.
