350 Tranny bolts
Discussion in 'The Garage' started by socal chevy, Sep 1, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    So Im about to bolt up the 350 to my tranny, and **** those bolts up high are so freaking hard to get too! I cant fit a torque wrench in there, so what do I do? How do I know if I got them tight enough, actually how do i reach them to tighten them!?!? :confused:
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    The best way to do it is take the dizzy off and get to the bolts that way. You are going to have to get into the engine bay...watch where you step.
    Adam
  3. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    about 2-3 feet worth of extensions and a wobble-joint.
  4. dyeager535
    26,979
    As mentioned, the extra long extensions and get to it from under the truck works.
    What I've always done is just get a small boxed end wrench (had a 12 point 1/2-9/16" craftsman myself) and do it that way. Yeah, it takes a few turns, but you can get enough torque on them, they will hold.
    If you've got the ratcheting box ends, those I believe will fit, if for nothing else than to get the bolt close to being fully seated, then hitting it with a real box end. (since the ends of the ratcheting are sometimes too big to fit into tight spots)
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive done it a few times... the easiest for the top two are done by straddling the engine and a box end wrench. I even made a longer box end by welding some flat stock to the wrench. That extra 10-12 inches made the job alot easier. And if the distributor is out... its a breeze!! Good Luck!!
    :waytogo:
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I know body lifts are gay, but a 1" lift makes this sooooo easy
  7. diesel4me
    Jul 24, 2003
    17,561
    941
    Massachussetts
    take the hump out..
    You can sit in the drivers seat and reach them if your tranny hump is removeable..THATS the easiest way! :D --I had a 3" body lift on my 74 K20,putting them in from underneath with long extentions was a peice of cake..pulling the distributor out helps make it easier to do from above as noted already,and having a long wrench with a narrow box end,or a "flip socket" style is best to tighten them from above--ratchets usually wont fit in there..no need for a torque wrench--just tighten them firmly,they only need 35 ft lbs.--not that much torque..none of mine ever fell out!.. :crazy:
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Awesome thanks for the tips guys... Isnt removing the distributor a b*tch to remove? I took it out once, and I dont think I want to do it again! :p:
  9. dyeager535
    26,979
    I don't pull mine. It's a tight fit, but it's doable. I put up with the hassle instead of pulling it, just makes more work.
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Removing the distributor is a breeze. Lining it up to put back in can be time consuming. Sometimes its taken me 20 minutes to get back in, other times Ive been lucky and got it back in on the 4th try...
  11. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    The hardest part about putting the dist back in is getting the oil pump rod lined up, usually if mine moves once I get it out you can take a flashlight and a long flat head screw driver and align the pump better so your distributer goes back in easier. But yeah a little body lift makes it waaaaaayyy easier to get to those bolts.
