350 tranny to 400???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Nov 22, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    I recently had my transmission go out on my jimmy and I would like to know if there are any mods to be done to put in a turbo 400???...........I also plan on putting in a crate HO 350 putting out 330HP and 380TQ any ideas if this tranny will be able to accomidate this extra power???
    1979 Jimmy 4" skyjacker, add-a-leaf, 35" M/T's, Body Lift purchased.
    2001 Pathfinder LE Mile Marker Winch
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You need a transfer case to go with the tranny. And yes the th400 will handle that power. My stock rebuild th400 with a 35 dollar B&M shift kit is working fine(And has been for the past 2.5 years) in my firebird and it runs 11.1s in the 1/4 mile.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. madups311
    Nov 14, 2001
    72
    VA
    will there be a problem with the driveshafts???
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Yes there will be a problem. The th400/205 combo is much shorter than the 350/203 combo. You can use the front driveshaft from the donor vehicle but will probably need a custom rear drive shaft, or lengthen yours.
