350 Tranny To 700r4 W/205 Trans Case
Discussion in 'The Garage' started by JimmyMan, Dec 12, 2006.
  1. JimmyMan
    JimmyMan Newbie
    Jul 25, 2005
    4
    W.Phx
    Does anybody know if it is possiable to swap out a 350 tranny and put in a 700r4 using the 205 transer case? i have an 80 jimmy with a 350 engine.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Search, I here non-payers can do that now. There is a trick to it as you need to run a spacer between the tranny and tcase but it can and has been done.
    Ira
  3. JimmyMan
    JimmyMan Newbie
    Jul 25, 2005
    4
    W.Phx
    Ok, i searched around and found the item number for the spacer 7q-35a. The 700r4 i have is 4x4. I understand all i need to do is trim about a 1/4'' off the shaft, then bolt up? This seems to easy. Any advice is greatly appreciated. Thanks
  4. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    Yea buy the shorter shaft from AA and have it put in the tranny, the shaft is heat treated and good luck cutting it
  5. sandawgk5
    Oct 28, 2003
    6,881
    Just buy the spacer and bolt up the 205. If you swap in the short shaft then you can have Tranny pan to CV clearance issues if you run a 1350 or bigger CV. If you are putting a 203 behind your 700R4 then the short shaft is the only way to go.
    Ira
