350 trans question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suzukirider85, Sep 15, 2002.
  1. Suzukirider85
    Suzukirider85 Registered Member
    Sep 11, 2002
    6
    i have a 1975 chevy pickup with a 350. it has been siting for a while and now the transmisson is shot. i am not that smart when it comes to transmissons but i hope the get the basics on the post. what do 4x4 use a long or short shaft? is there a difference between a 350 and 350 turbo or is there no plain 350 and just 350 turbo. and will a 400 turbo fit my 75 350. thanks
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I can answer some of that. A 350 is a TH350 is a General Motors Turbo Hydramatic 350, all the same. The "turbo" part just comes from the Genera'ls brand name, so it's not any different from a regular 350.
    A 400 will go, and is a hell of a good tranny. You will, however, have challenges fitting it to your transfer case, and someone else will tell you more about that.
    -- A
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the 400 is longer. it will not fit without a new x-member, worked driveshafts and placing the t-case handle in a spot where it will not bind.
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Plus a TH350 has a 27 spline output shaft. A TH400 has a 32 spline output. In a 4x4, a turbo 400 will not fit to a transfer case that was mated to a turbo 350, and vise versa.
  5. Suzukirider85
    Sep 11, 2002
    6
    now when i look for a replacement will i need to go for a short shaft or a long shaft(i have seen both in the local trader post and want to get the right one). thanx
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the best bet is to either get a 350, so that you KNOW it will work with your 203, or look for a 400 already mated to the t-case of your choice.
  7. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    if you stick with the 350, yes you will need the short shaft. It sticks out the case about 7/8 of inch. and of course the won't be a tail housing on the tranny.
    the turbo 350 has 4 output shaft options. 3 are for 2 wheel drive vehicals. the last one is for all 4 wheel drives.
