350 Turbo problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dave_90_blazer, Oct 19, 2004.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Ok, my buddy with the 85 truck found out today that the trans leak he has is the t-case(NP208) is loose due to the fact that the trans case where the top t-case bolts go in is cracked?!
    my question, is the 350 from a car(with the tail shaft housing removed) the same as the 4x4 one?
    also, should this truck have a brace from the t-case to the engine/bellhousing bolt?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    no the 350 from a car with the tail housing removed is not the same. the out put shafts are different.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they are differene, BUT, if he has a 700r4 in it curently then you can use the tranny to replace the 700r4 with a little cut of the output shaft and a 1.75" spacer.
  4. dave_90_blazer
    Jan 1, 2004
    688
    nope, he has a 350 in it now
    is the case the same between a 350 longtail and a 350 shorttail?
    if yes we have a longtail case we can use
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    is he using a scacer between the tranny and tcase adapter?
    yes the cases are the same.
  6. dave_90_blazer
    Jan 1, 2004
    688
    I don't thimk so
