350 versus 400
Discussion in 'The Garage' started by jacob_coulter, Jul 11, 2006.
  1. jacob_coulter
    jacob_coulter Registered Member
    Jun 28, 2005
    12
    USA
    My friend was going to replace his blown 350 motor on his 78 k5 blazer, and the local engine shop charges about the same price for either a 350 or 400 rebuilt long block. His Blazer originally came equipped with a 400, so this will be the 3rd engine.
    All things being equal, is there any downside to going with the 400 over the 350? I've heard the 400 is better for low torque, and the obvious cubic inch advantage.
    I'd appreciate any input.
    Thanks again
  2. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    No replacement for displacement. :)
    -Avery
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    zi made the switch from a 350 to a 406. The low end torque is much better on the 400. The 400 is a mean motor for a small block, but it's a beast to keep cool.
    I'd say that is why a 350 was used to replace the original 400, probably heat issues.
  4. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I'm planning a 383 now w/ Vortec heads and the Howell MPFI. I thought about putting that same top end on a 406 but all the drilling steam holes in the heads, heat issues, blah blah............I'm sticking w/ the 350 block. I figure the 23 cubes I'm missing w/ a 383 vs. 406 is not worth the simplicity and reliability I'll have by going w/ the 383. Just my .02.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    400's are nortorious for over heating issues. Build a 383 instead, they have plenty of low end torque and aren't prone to the overheating issues associated with the 400. 400 blocks usually crack in the lifter valley also way more than a 350 block ever does. This is because of the simeased cylinder walls and the lack of cooling.
