350 vs. 400 whats the difference?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SoulStyles, Jan 9, 2003.
  1. SoulStyles
    SoulStyles Registered Member
    Nov 25, 2002
    6
    All right, I bout a 1977 Jimmy and I presumed it had a 350 in it. I ran the VIN number against GM's vin codes and it says my Jimmy was equipped with a 400. How can I tell if my engine is a 400 or a 350? Im new to 4x4ing so I could use a little help.
    Thanks a lot.
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I usually check for holes drilled or weights on the harmonic balancer. There is also a freeze plug difference sometimes but to me it is easier to check the balancer
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Also check the block, should have 509 cast in it down underneath in front of the starter in numbers about 1" high.
    If it is a 400, that's a late Xmas present in my book. /forums/images/graemlins/thumb.gif
  4. SoulStyles
    Nov 25, 2002
    6
    so if it has the 509 cast in the block it is a 400?
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    The difference?
    My 400 spit a rod through the #4 cylindar wall at 10,000 miles.... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    My 350 hasnt.... /forums/images/graemlins/smile.gif
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    You can also get the casting numbers off the back of the block beside the distributor and go to mortec.com and identify which you have. Cross your fingers /forums/images/graemlins/cool.gif.
  7. dyeager535
    26,976
    As the link above says, go to www.mortec.com But go with the suffix code. A little hard to read, but less likely to have the same suffix code on two different CID engines, unlike the casting numbers which sometimes were quite generic regarding CID.
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    No 400 will use the same casting number as any other small block. The 400 block is a totally different animal.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Another less reliable way of identifying the two is by looking at the freeze plugs on the sides of the engine, I think the 350's were more common to have 2 plugs per side and the 400 had 3 freeze plugs per side. Thats not a full proof rule because there are a few exceptions but it can help narrow it down. If it is a 400, then bonus, you'll love the torque it puts out over a 350.
  10. dyeager535
    26,976
    The casting number reference was just a general statement...if nothing else uses a 400 casting number, fine, but at least with suffix code you will know if its original (or very close) to the vehicle it is in, replete with HP #'s and year of vehicle. I mean if you are going to look at numbers, why not get ones that tell you a bit more?
  11. SoulStyles
    Nov 25, 2002
    6
    where do i get the suffix number? Is it in the same location by the distributer?
  12. dyeager535
    26,976
    No, its listed at the www.mortec.com site, but typically it's behind the alternator, on the flat pad just in front of the passenger side cylinder head. Kinda hard to get too to clean off, but it's not THAT tough usually.
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The 400 block doesn't have a water jacket between cylinders 3 and 5 - 4 and 6. They call it "siamesed cylinders." This is how they were able to acheive the bore size with the same size block. They will alway run hotter than other small blocks. I know this doesn't help you identify it but it is the most significant difference other than CID that I can think of. /forums/images/graemlins/crazy.gif
  14. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    dont let them scare you off...my dodge 318 runs way hotter than my 400... no complaints here. the torque is nice, specially if if you're not geared for big treads
    Ryan
  15. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    The 400 is a good engine. Like some previous posters said, it will have 3 freeze plugs down each side rather than two. It may have a "fake" freeze plug but it is obvious. A 400 is externally balanced rather than internally balanced so you should be able to look at the harmonic balancer and tell if it has counter weights on it. On a 350 the harmonic balancer is actually a dampner. There are some differneces in the heads, flywheel, balancer, and oil pump drive shaft. The heads have steam holes drilled in them to help aleve the overheating problem. Typical 350 heads can be modified with steam holes to work. The flywheel and balancer are set up for an externally balanced engine, and the oil pump shaft has a little machining for clearancing.
    John
  16. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    The 400 has a bigger bore (4.125in) and a longer stroke (3.75in) then the 350. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
