350 with a supercharger
Discussion in 'The Garage' started by adamforsythe, Sep 2, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What would it take to put a supercharger on a well taken care of 350 engine with less then 15,000 miles (since last oct. I have put a grand total of 1000 miles on the engine)?
    Tell me everything. I want this engine to plant you in your seat. If I have to change everything in the block I will end up building up another 350 that I have.
    Adam
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Carb, fuel injection?
    Post a little more info about the motor and how far you are willing to take things...
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The folks at Whipple make a bolt on kit for TBI GM trucks. But it'll set ya back around $4,500. :eek1: Oh yeah, once you go to forced induction, you MUST run premium fuel to keep the detonation monster at bay. So figure that into the long term cost...
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Unless he uses low compression pistons...
    Also if your gonna change the pistons get forged pistons... Forced induction is ALOT harder on the internals like crankshaft, conn rod, and pistons.
    Be interesting to see how much hp and tq you can squeeze out of a supercharged tbi setup...
    Does that kit come with tbi upgrades?
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. The only reason to run low compression pistons with forced induction is so you can crank the boost up higher. So you still need premium fuel. Forced induction is VERY unforgiving of detonation. It greatly increases cylinder pressures, which increases the tendency for detonation, which increases the tendency for pistons to get holes in them... :rolleyes:
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    So you can't run regular even if you drop the compression a point or two before the huffer goes on?
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    carb, 4 bolt main
    Adam
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    By the way what is the specs on these two styles of superchargers?
    Superchargers, Roots Style Kits
    Superchargers, Centrifugal Style Kits
    Adam
  9. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    I would also recommend going to a forged bottom end if your gonna run your boost higher than 6-7psi just my opinion
  10. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    That is the purpose of using forced induction Harry......
    to run lots of boost, otherwise the blower must be underdriven to the point that it is hardly worth the investment.
    Run enough static compression so the engine makes enough power under no/low boost conditions (roughly 8:1cr) then setup the drive pulleys so the blower is creating positive manifold pressure w/o detonating the engine.
    Personally i don't think Adam is ready to take on a supercharged engine project.......sorry to be blunt.
    It is not a project for the inexperienced builder :bow:
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. The whole idea of forced induction is to force more air into the combustion chamber, so that you can also force in more fuel with it. Combustion chamber pressures go WAY up.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Which is exactly the point that I was making. The whole idea is to make way more power, by increasing volumetric efficiency far beyond 100%. Many hard core blower motors have compression ratios down around 7:1, while running 40-80 pounds of boost. :eek1: But at that point, even premium fuel is out of the question. Those guys are buying 110 octane racing fuel, running cams that are optimized for boosted engines, and using electronics to back out lots of timing as the boost levels climb.
    There are plenty of complete kits on the market that will work just fine with a bone stock engine. By keeping boost in the 4 to 8 pound range, they give a decent increase in power without having to build an engine with a forged crank, unobtanium rods, forged pistons, O-ringed heads, etc.
    Moneypit has a buddy that's running a Whipple setup on a bone stock TBI 350 Suburban. He says that it goes like a bat out of hell, but it has eaten three 700R4's so far... :doah:
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My thinking usely evolves cost. I don't know, but I would think swapping in a BBC would give you the grunt you want at a lower cost then a supercharged SBC. I may be completely wrong, but that's just my thinking.
  14. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    40-80 pounds of boost.........huh
    I think/hope you meant to say 4-8psi of boost..... :bow:
  15. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
  16. GruntHunter
    GruntHunter 1/2 ton status
    Apr 28, 2002
    145
    Florida (Space Coast)
    Not worth the trouble or headaches
    We had a guy in Elmira, N.Y. back in the late 60's that bolted a 471 on a stock 312 Ford with 2-4's on top of that. He had to be extremely careful NOT to let it lug down or it'd backfire up through the carbs. He slipped up downtown going around a corner one afternoon and blew his crankshaft (and many other parts) right through the oil pan and out onto the street. Made quite a mess.
    Bottom line, you can't use stock or high compression pistons and the entire engine has to be built for a blower installation. Now, with that said, Ford in '57 did offer a 312 with a blower to keep up with the '57 Chey FI, but of course they wern't putting out the HP that you'll most likely put out.
    Lotsa Good Luck ! ! !
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Only for stockers. There are folks out there drag racing, street racing, etc. that run insane amounts of boost. And yes, I've seen guys claiming to be running 80 PSI. :eek1:
    I know a guy that's running 29 PSI at full boost on a stock Duramax diesel. It freakin' hauls a$$! :bow:
  18. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    The whipple kit uses a twin screw supercharger with teflon strips on the blades for more efficient compression of air, but it is made to bolt onto a completly stock motor. as long as your not surpassing 7 psi, i doubt you will be breaking crankshafts, rods, pistons, etc...
    As for 80 pounds of boost... i'd guess they rebuild that thing after 25 passes at the strip. More boost = faster rebuild time.
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    That is a whole nother discussion, 29PSI on a Duramax is nothing...
    A lot of the really big hot rod light duty diesel guys are pushing over 100PSI
  20. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    just run it on alcohol, takes care of detonation and cools everything down after the blower builds up all that heat.... :laugh: not sure what nitromethanol goes for by the gallon though...... :doah: anyone?
