350 with spreadbore intake with 454 tbi adapter plate?
Discussion in 'The Garage' started by juanblzer, Feb 13, 2006.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I need help fellas!
    I have an 84 k5 with a 350 small block crate motor in it.
    I bought a 454 tbi adapter plate so I can "bolt on" 350 tbi stuff. I really need some guidance on how I mount the sensor brackets and exactly how the throttle cable attaches to the tbi. Has anyone done this? Anyone have pics?
  2. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    ttt
    ttt
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    The stock TBI sensor brackets won't work properly - in the same position, anyway. The TBI intake is a lot different than the carb intake.
    You could always use a TBI intake. The center two bolts on both sides need to be drilled so they match the angle of all the other bolt holes.
  4. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    u run tbi with an hei distrib? does that work?
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    tbi to spreadbore
    yeah, i've done the "redrill thing" before... I'm trying to get away from doing that. This is supposed to be easier. :D
  6. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i did that redrill and decided that i didn't like it so i got an adapter
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yeah, you can use a large cap HEI if you have a fully computer controlled one. My 86 K5 is a california model so it had a computer controlled everything (Carb, dizzy, etc.). Not sure what years have it, but there are some floating out there.....maybe mid 80's before the TBI came out????
