350c tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jkort77, Jan 22, 2002.
  1. jkort77
    jkort77 Newbie
    Jan 19, 2002
    3
    Waunakee, WI
    I have a 350c tranny out of an 80 Blazer, I put it in my 77 Chevy pick-up, but I do not know where the wire goes for the lockup converter. The tranny stays locked up until I stop.
    Please help.
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    You need a modified brake switch that has two poles (four blade). One for the brake lights and the other to interupt the lock-up on the torque convertor. The lock up is wired to a switched 12 volt source and then run through the brake switch which breaks the connection to the lock up when the brakes are applied.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    throw that tranny out. i had very bad expeience with the torque converters, burn out like 3 of them in a year. that was on my camaro. stick with the regular th350.
    my 2 cents
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  4. dyeager535
    26,980
    I may be showing my ignorance of 350C's, but if it were a 200C, 200-4R, or a 700-R4 that was staying locked up all the time, I would say your torque converter clutch solenoid had failed.
    However, if you don't have any power to the TCC solenoid now, (the plug on the tranny) I'd say something internally is messed up.
    Unplugging the TCC solenoid from a power source on the above mentioned trannies, even when its staying locked up all the time (it has failed) will cure the problem, short of replacing the TCC solenoid.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
