35inch tires/2 inch lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kodiak, Sep 2, 2000.
  1. Kodiak
    Kodiak 1/2 ton status
    Mar 17, 2000
    178
    Kodiak Island, Alaska (the emerald isle)
    Has anyone ran this combo? I want to run 35x12.50x15 on 8inch rims with a 2 inch lift. I don't want to add a body lift. This is on a 71 blazer. How much trimming is going to be needed? Thanks
    http://kodiak.coloradok5.com
  2. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    too much. I'd recommend at least a 4" lift and a Little trimming. I'm going to run 33's with a 4" lift and no trimming (I hope) Don't forget that as you get that high in tire size you need to be sure your rear gears can handle it. It's adios to my 3.08's in favor of 390's. You may need a new speedo gear too, I will.
    "who dares wins"
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    33's fit fine with a 4" lift. I want to run 37's with a 4" lift... now where did I put that sawzall? I'll keep dreaming for a while.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I had to trim a fair bit off my front fender with 35's and a 4" lift.[​IMG] I am probably going to replace those with 37's as well and will probably have to do even more surgery!!
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    You should also consider some 10" rims for that tire size. An 8" rim will look funny and make the tires wear faster. At least that's what happened when I had 33X12.50 15s on 10", then 8", then back to 10" rims.
