35's & 454, what gears again?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Speed-demon, Nov 21, 2001.
  1. Speed-demon
    Speed-demon Registered Member
    Sep 12, 2001
    38
    Alberta
    35\'s & 454, what gears again?
    I have 2.73 gears 33's that are getting ditched for 35's
    a bitch'n 454 and rebuilt tranny. I putt the lift kit & tires on it and next thing I know, I blew the 350. Next thing tthat went was the tranny. lol.ha ha I think it's time for some new gears!
    I drive it on the hiway once in a while so I need to keep the rpm down as much as I can but, can you just amagine.....
    This Sucks! As soon as the bodyworks done I gotta change my gears. Does anyone have any sugestions what would work best? Old pops has a autowrecking shop for me to choose from.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: 35\'s & 454, what gears again?
    If you have a 700r4 you should go with 4.10s. With a 350 you go with 4.56s but on the freeway you will be turning to many rpms for the big block.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Keep the 2.73s. It'll be gutless but it'll get good mileage. [​IMG]
    I'd probably get 4.10 gears. With a BBC and no overdrive though, 3.73s are possibly an option, but you'd give up some performance.
    Tim
  4. Speed-demon
    Sep 12, 2001
    38
    Alberta
    I'd probabley be happyer with 4:10's with 35's but I wonder what my rpm's would be on the hiway at a 120km/hr? I don't know.... I'll probably end up going with the 3:73's........In 4 low with the 208, it should be all right........
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Don't spend the money on gears for a tenbolt rear with
    454 ! Go 4.10's and 14 bolt rr &amp; pray for your 700r4 !-Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  6. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    You want to keep a big-block in the lower RPM range where the torque is...keep this in mind.
    9/11/01..Never forget...Never forgive
  7. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Big Block shouldn't care what gears are behind it. If you keep the 10 bolts, don't go any lower than 3.42
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Big blocks do care. Tey dont like being reved high and dont like high rpm cruises. Keep the rpms around 2,000 for cruising to keep it alive.
  9. RedDwarf
    May 9, 2001
    816
    Read my post again.
  10. Speed-demon
    Sep 12, 2001
    38
    Alberta
    Hey thanks RedDwarf, I think that what I'm gonna end up doing. I think with all the botom end I have with the 454 It doesn't make that much of a differnce and it will make it a little tougher. And use the cheap ujoints, instead of the bullitproof ones, so that my axles might last
