35's and 3.42 gears
Discussion in 'The Garage' started by Chris87K5, Nov 7, 2002.
  1. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    35\'s and 3.42 gears
    Is this a bad idea? I plan on getting a 4" lift soon and i want to run 35's but i wanna know if its gonna be a total dog or not. I probably wont have money for gears or anything for awhile. Will this be a mistake? /forums/images/graemlins/confused.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Re: 35\'s and 3.42 gears
    My buddies is set up like that and his runs good plenty of power his is a 90/91 nothing done to the motor.
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    it is ok, but i am looking to go to 4.1 ASAP,
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    That would be a good way to over work your 700R4. I temporarily have a 3.40 rear axle in my truck with 31's and it is a dog compared to the 3.73 I took out.
  5. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    DO NOT RUN OVERDRIVE!! If you keep it in drive it will keep it closer to the engine's power band. Overdrive will keep it too low. If you drive the truck in overdrive with that set-up you had better start saving your pennies for a new transmission because you will need it.
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I've been running 35s with a 3:08 for a couple of years now. I run it about 110 miles a day......doesn't bother me much, but I'm an old fart.
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yeap, im runn'n 33's on 3.08's, works fine for me, cept i have a sm465, hehe, i have all the low gearing i want to get me going, ferget the over drive, all its good for is high way driv'n, and as someone once said "real men dont care about gas mileage", but of corse im young, and i dont drive far to work, and i have an 87 chevy. /forums/images/graemlins/thumb.gif
  8. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I'm running 33's and 3.42's and It sux major. I wouldn't recommend running 35's. My engine bogs down so bad that I usually run her in 3rd and shift up when I know I have a LONG Flat stretch.
  9. st08x
    st08x Registered Member
    Oct 17, 2002
    84
    Texas
    i have 35's on my rig and it does fine... it was actually worse with 33's but they were swampers and heavy. to be honest i have no clue what my gear ratios are but its and 82 with a 3 speed transmission. i havent been able to find the gear ratio but its probably stock. i garuntee lower mileage though.
  10. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Yea you don't have overdrive. When the tranny goes into forth and the converter locks up it really lets the engine bog. Without overdrive it would be OK. I personally would still like to have a little more bottom end. My 72 w/the 4 speed has 3.08's and 33's and it does good until you get out of first /forums/images/graemlins/rolleyes.gif If it wasn't for the LOW first gear I don't see how it could be done.
  11. st08x
    Oct 17, 2002
    84
    Texas
    yea thats the nice thing about having a 3 speed but on the highway i can watch my gas gauge go down as fast as the people passing me
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    As others have said, it will be OK but you will not use overdrive AT ALL. You should think seriously about what you want to do in the future right now. Your best next step is to upgrade to 3/4 ton axles for the strength and lower gears, but if you buy 15" 35s right now, you will be screwed later on the 6 lug / 8 lug thing. It is much easier to go with 16 or 16.5 inch wheels and 8 lug when you go to the heavier axles.
  13. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I had 31's and 308's... man that was terrible. It even ate more fuel on the highway, and had problem staying in OD.
    I moved up to 33x12.5's and 373... that is acutally quite nice for the style of driving I do. Most of the time, Im in OD, cruising around 60. Fuel economy is acutally quite decent this way. Over 70, fuel economy drops significantly.
    On 35's, I except it to be a tad bit slower, but not really by much. My theory is that your radius only increased by 1.5", and maybe 10 lbs more rubber on the outter edge.
    Theres this wacky kid I've seen with some 2.42 or something in the mid two's, on a 12 bolt rear, and 37" tires. He has some super low first gear, but he beats the snot outta it. Might be why he's getting a new rear end. /forums/images/graemlins/smile.gif
    I've acutally flat towed my mustang in OD with 35" tires. Not terrible at all. THe real hilly areas would drop down to third and floord, would keep 70mph.
