35's and 3.73's who's running it?
Discussion in 'The Garage' started by UseYourBlinker, May 15, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    35\'s and 3.73\'s who\'s running it?
    I currently am running small 33's and in the near future (when I install my BDS Springs) I'm gonna go to 35's. Any issues with 3.73's and 35's besides a bit slow off the line? I had 33's and 3.07's for 2 years,should I expect the same thing? Thanks
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: 35\'s and 3.73\'s who\'s running it?
    You should be sluggish off the line. with your 350, you should be okay, though. If you are running a 700R4 tranny, you might not be able to use OD as much. Give it a try and see. If your tranny does a lot of downshifting at highway cruising speeds, run it in D to save the tranny.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I run 35's w/ 3.73 gears.... No drag racer, but it works good for daily driving.
    Marv
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    Yep I have a 700r4 tranny.. Thanks for the info. I will change the gears but it won't be for awhile.Way,way,down the line.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    this may sound dumb but WHAT does OD and D stand for.
    Bryan
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Thats what I'm running along with a tired ole 305.........
    35x14.5s actually.
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    You know i got 35's and 3:73's and so does Greg72 for now.
    But you got the 700r4 that has a lower first and an overdrive.
    Us first gen guys are running TH-350s.
    I like it for now. Eventually I'll get some LOW gears and a built overdrive.
    The 3:73's and 35's are nice for the freeway (with 1:1 3rd).
    I'm pulling like 2800 or so keeping up with freeway traffic.
    It is a little sluggish outta the hole but with a few bolt ons to the engine make it better. /forums/images/icons/smile.gif
  8. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    D = Drive
    OD = Overdrive
    D in a 700R4 is equivalent to 4th in a 4 speed manual. It is a 1:1 ratio in the tranny. OD was created for more optimum fuel economy at highway speeds. In the 700R4, it is a .7:1 ratio. That gives you 30% lower RPMs in overdrive than in drive.
  9. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    My first Blazer had 35's and 3.73's. My current Blazer has 35's and 4.10's. There definately is a difference in quickness off the line. Of course, the gas consumption is higher too!
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    aHH ok i c
  11. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I have 3.42's and I'm upgrading to 3.73's. with the current gears and 35's I still smoke the tire going aroiund a corner ( I need to stop that, my poor tires /forums/images/icons/smile.gif ). I will like the 3.73 because I should cruise around 2400 RPM at 60 mph (now I'm a little under 2200)
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'm running 3.73s & 28" tires on my wife's Jeep. Its a daily driver w a 318 and an O/D trans. Sounds like you're geared way too high to me.
  13. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    35s with 3.73s here. Of course, I have a Th350. I run around 2500-2600 rpm going 65.
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    That setup works fine with a 427 Big Block! /forums/images/icons/wink.gif
    My highway RPMs are nice and low.....but getting off-the-line takes a lot of torque from the engine.......
  15. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i had to settle on 3.73s when i blew up my stock rear axle.when i replaced it i had 4.11s in the other axle.i wouldnt want to run 35s with 3.73.but until i get the dough thats what i got.
  16. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I have 3.73 with 35" tires. I hate it I've got a set of 4.56 on the shelf just waiting til I can afford a locker for the front. It's pretty nice on the highway thogh. I use to have a suburban with 3.73 and 35" tires and a 700R4 it didn"t seem as sluggish off the line as my blazer is, but it would'nt pull OD till around 75 mph. my 2 cents
  17. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i run 36" TSLs and 3.73s with my tired ol 350 (154,000mi)
    SLUGGISH! /forums/images/icons/frown.gif but i'm gettin 4.56s really soon though /forums/images/icons/wink.gif
  18. ChevBlazin
    Feb 4, 2002
    332
    I would have gotten 4.10's or maybe even 4.56's, but I dont have overdrive and didnt want to run the high R's on the freeway.
  19. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I ran on the street and rockcralwed with 35s and 3.73s for about 3 months. No problems, other than a little slow off the line. I stepped up to 4.56s and it was alot nicer all the way around, but are almost always driving in OD. I have 3.42s and 35s in my Suburban with a 700r4. I dont mind it since I can tow my boat down the freeway at 80 in drive and no problems, a little slow in the hills, but I just downshift into 2nd gear and have no problems. The hills are of course windy and steep.
    Dan
  20. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    3.73's and 35's are decent.
