35's and no lift?
Discussion in 'The Garage' started by RustBuket, Oct 20, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    35\'s and no lift?
    I am really skimpin on the funds right now! I was wondering if I would be able to buy 35's and hack the sh!t out of my fenders to make them fit with no lift. There is only mud/snow/dirt here there isn't any rocks so I don't really have to flex too much. I could even run with the sway bar to minimalize it if thats what it would take. Could I do it or would I run into some serious problems? /forums/images/graemlins/1zhelp.gif I just really want to run 35's BADLY!!!!
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: 35\'s and no lift?
    If you're prepared to hack-away, you can fit 35's.
  3. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I got 36's on a toyota with no lift. So yes you can make them fit if you trim enough.
    Trey
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Click on the link in my sig to see apic of 35's with no lift. The front tires rub on the rear part of the front fenders just sitting there. I'll be putting my 4" lift on in 2-3 weeks
  5. RustBuket
    Feb 21, 2003
    1,618
    Its looking like I'd have to trim a fair amount.....
  6. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I got 35's with just finder trim and no rubbing. And yes I wheel it hard, just look at my pics. I am the whit K5 LOL
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  8. RustBuket
    Feb 21, 2003
    1,618
    Thanks for the support guys! I think I'm going to go hack some fenders! (when I get the tires that is)
  9. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    If you have a 700R4 you should probably not run w/ OD if you go w/ the 35s though. I'm running 33s and when I use OD my tranny spends a lot of time going back and forth between gears. Do a search and you'll see tons of info on that. Even break downs of what gears should be ran w/ 35s. Just my .02 /forums/images/graemlins/thumb.gif
  10. RustBuket
    Feb 21, 2003
    1,618
    I've got a TH350 I'm pretty sure so I think the tranny would be fine. I'd have to hunt down a 14b with 4.10 gears and a 4.10 gearset for the front ten bolt but that wouldn't be absolutely necesary. I know I know it would be hard on everything to be geared so high but I just really want the coolness! There is no hardcore 4 wheeling around here anyways. At the most, I'd run in some snow, very mild mud.
  11. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    coolness is only half of it lol..i know what you mean but you gatta do things fairly right..what gears are you running right now?
  12. RustBuket
    Feb 21, 2003
    1,618
    I don't even know what gears I'm running right now.... /forums/images/graemlins/confused.gif Is there an easy way to find out?
    Its not like its my DD, I only drive it to school like once maybe twice a week. I drive it like 3x a week usually. So it hardly gets driven.
  13. RustBuket
    Feb 21, 2003
    1,618
    TTT
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yeap...if you dont mind changing the rear diff fuid lol..take the cover of and look on the ring gear for the chain of numbers..your looking for two numbers next to each other liek 14 and 11..or 14 and 10 or something..divide the two and there ya go!
  15. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    How about a 3" body lift?
  16. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    right on /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif hack them fenders my favorite method is with a sawzall. imho your next upgrade after tires should be 3/4 ton running gear with lower gears. but i do like your attitude!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. RustBuket
    Feb 21, 2003
    1,618
    Thx reeser, I would lift it but I don't have the $. Also, the body is shat anyways. So, might as well cut er up. I may go with a body lift but I heard its not that good.
  18. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yes..to a certain degree maybe...
  19. RustBuket
    Feb 21, 2003
    1,618
    To what are you saying that to? Hackin sheetmetal? /forums/images/graemlins/confused.gif
  20. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Thats just with helper springs front and rear...a guy named schmuck on the board...I've wheeled with him a bit, he has no flex, and it rubs very rarely, as you can see he does get in the mud with it
