35's and what gears again?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Nov 20, 2001.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    35\'s and what gears again?
    This is what I have:
    Stock 88 K5
    -31's
    -700-R4
    -3.08 gears
    I want to run 35's but am not sure as to what gear ratio I should look for. I did a gear calulation in Four Wheeler and it indicates I should run 3.73 and have the same affects as my stock K5. However, I know 3.08's suck even with 31's. So would I be safe to run 35's and 3.73 or should I go with 4.11's? It is going to be a daily driver and I want to be able to run in overdrive to keep descent gas mileage. Does anbody have this same set-up or what are you guys running?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: 35\'s and what gears again?
    I would run 4.11s. I have 4.56s in the Jimmy with 35s and it gets up and goes. overdrive helps keep the rpms down. As for just freeway driving 4.11s would be good. I use to have 3.73s and 35s on the Jimmy and it was okay but I wanted more get up and go.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    go with 4.56s, then someday when u decide that 35s are weeny tires and want 36s or 37s, you can stick with the same gears. =)
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    J
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I have 33's and 4.11's with no overdrive and not only is the acceleration great, but the RPM's on the highway are still OK. You are going with a bigger tire than me AND you have an overdrive. Get AT LEAST 4.56's otherwise you're going to hate yourself later. As long as you don't like cruising to work at 90 mph, then you could even do 4.88's. If I had an overdrive I would have gone 5.13's and 33's.....OH YEA!
    '73 K5
    Chevy good...Ford bad
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have 4.10's and 35's now and it is ok, would much rather have 4.56's but they are VERY hard to find
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i need overdrive, got 4.56 s in my 10 and an 12 bolts , high rpms lag , 32s and my old gears was kool kruising the freeway ...
    dents ....
    O R D's axles
    NO BREAKAGE :)
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    3.08s and 31"s Bahahaha, oh wait...thats what I have. Im sticking with 31"s cause a city slicker like me doesn't really worry about getting big tires. I am dumping the pukey 3.08s for 3.73s.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I also have an 88 k5. I'm runnin 35in Pro Comp AT's with
    4.56's and I dig it! It gits out of the hole, pulls my boat and
    cruises on the hi-way no problem.-Jim
    88 5.7 5in lift( I tell my wife it's ten) 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  10. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have 35's and 4:56's in my 89 and it works great.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ditto on what Mikey said. I have 4.10s and 35s. I ACHE for 4.56s. I have a 700R4 now.
    Soon, I won't have overdrive, so it won't matter anymore. I'm getting bigger tires now.
    Tim
  12. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I have 4.11s in my truck with 35s and i like them ok i guess but i really wish i hasd an overdrive cause i dont really like being at 3000 rpm on the highway
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  13. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have an '85, 305, 700R4, and 35s. I had 3.73s and it sucked. Went to 4.56s and have never been happier. 4.10s and 4.56s would have cost me the same, so I went bigger. I would have been disappointed with 4.10s.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have 4.11's and33's, and it winds out way too fast o nthe highway, or maybe I just drive too fast, but the RPM's are too high for my liking. If it was me, go with 4.11's and 35's, I kinda wish I had gone with 3.73's for better highway in mine, but oh well. So if you drive on the highway a lot, get 4.11's but if not, then 4.56's
    90K5
