35's with 10 bolts?
Discussion in 'The Garage' started by badassblazer03, Nov 17, 2003.
  1. badassblazer03
    badassblazer03 Registered Member
    Oct 2, 2003
    82
    Amherst, NH 03031
    35\'s with 10 bolts?
    will it work? I plan on running mtr's mith a 4 inch lift on my 82 k5. Any ideas on how much ground clearence I can expect.
    thanks /forums/images/graemlins/k5.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: 35\'s with 10 bolts?
    Do you drive like an a** or do you drive like a calm, considerate human being? That's the first question you must answer.................... /forums/images/graemlins/thumb.gif
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I run 35's on my 10bolts. Not a problem yet but I dont wheel it very hard because of the 10bolts. Try to move up to at least 3/4 ton gear at least if you plan on wheeling it at all.
    Nick
    Nick
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I would guess about 7-8 inchs ground clearence to the diff. I have 35s on my 10 bolts and they are holding up (knock on wood) they have been on there for about 5k miles, The previous owner had 36s on it best I can tell beacuse that is what the speedo was calibrated for, had 31s when I got it though.
  5. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I'm running 315/75x16 MTRs, they measure 34.5" on a 8" wide rim and 33.5" with the weight of the truck on it and at 34psi. Ground clearance under the front diff is 10.25"; rear is different since I'm running a D60 back there.
  6. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    89 k5 10 bolts front welded and 38's yeah axle shafts break when there is axle hop but i have beaten it pretty hard and am impressed don't have money for a 60 but got plenty of old axles shafts laying around /forums/images/graemlins/grin.gif
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    10 bolts will work on 35's. IF you plan on wheeling it hard I would suggest going with a GOOD QUALITY ring and pinion setup by a good shop with an aftermarket carrier like a Detroit, or an ARB. Aftermarket shafts dont hurt either, Moser's seem to be pretty good. O yeah I wheel the piss out of my 10 bolt front, lots of wheel spin and throttle involved and all i have broken is a chitty superwinch hub. I did blow up the rear Govloc, but that is because its a horrible design.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I beat the piss out of my truck with 35" tires for years with a 10 bolt front and never had any issues. My rear was a 14 bolt though, destroyed the 10 bolt with 31s on the road even before I lifted it.
