35's with 2 1/2 lift?? Cutting?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jms, Jun 8, 2001.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    35\'s with 2 1/2 lift?? Cutting?
    Anybody running 35's with a 2 1/2 inch lift? With swaybar disconnects? How much did you have to cut the fenders? Besides fenders, do they rub anyplace else? Info's greatly appreciated, michael
    <A target="_blank" HREF=http://desertrider.coloradok5.com>http://desertrider.coloradok5.com</A>
  2. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Re: 35\'s with 2 1/2 lift?? Cutting?
    I had 35" BFG all terrains with a 4" lift for a long time. They would just rub the fenders closest to doors when I was turning and articulating at the same time. No rubbing anywhere else. If I cut off only an inch at the very end of the wheel well I think it would have been fine. But that was with 4" of lift.
    That's because I'm the devil.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You'd need atleast 4" to clear 35's without major cutting.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I run 2.5" lift with 33's and have only rubbed a couple of times...Your going to have to cut some metal[​IMG]
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well i'm running just that on my 83 with a 2.5 and 35BFG's
    And yes i had to cut the back fender area and i also did the
    front area to because i don't have the front body mount's
    in. I think that if did have them in there would'nt be any problem. As it sits right now i dont have any problems.
    Hope this help. Eric
    Lost? i'm not lost i'm just disorienated
  6. Re: 35\'s with 2 1/2 lift?? Cutting?
    i used to run my 35s on a 2.5" lift. i ran with my sway bar all the time though. i cut the fenders too. i didn't rub but i didn't have great flex either. i've sense gone up to a 4" and more trimming with no sway bar and i get some contact on full stuff. here's a few pics of when i had the 2.5" lift. with more trimming and my 2.5" i would have been fine. plus my truck drove a lot better with the 2.5 then the 4. hope this helps[​IMG]
    http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/pfd236582e67d754877fc177175b0244e/fe6b3fd4.jpg
    <A target="_blank" HREF=http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/p0c40885429e33f77b4780f165137f6cd/fe6b4057.jpg>http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/p0c40885429e33f77b4780f165137f6cd/fe6b4057.jpg</A>
    <font color=blue>Striving for K5 world dominance</font color=blue>
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm guessing you want to run 35x12.5's. They will probably not fit with a 2.5". I know a guy that ran 35x9.5's with that lift with no problems, though.
    90K5
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    pscromitt on here runs 3" and 39s but his fenders are slightly trimmed.
    <font color=red>Sherman, Tx
    "I'd Rather Be a Fencepost in Texas than the King of Tennessee" -Chris Hall
    TEXAS COUNTRY PRIDE
    </font color=red>
  9. jms
    Jan 24, 2001
    1,683
    Fellows, thanks for all the input. Any idea what the 35x9.5's are? Same as Q78? I like the sleeper look of skinny tires; I'm running 33x10.5 right now; the only ones I could find in 35 is MT Baja Belted 35x11.5($$$?). Concerns about lift height is garage height (duh!) and center of gravity/stability; wider tires would help here, I suppose. Anyway, wife's going to be out of town, I've got too much to do at work, otherwise I'm bored here in NE, so lifting the truck sounded like a good idea.....michael
    was fun while it lasted, <A target="_blank" HREF=http://desertrider.coloradok5.com>http://desertrider.coloradok5.com</A>
  10. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Check out the Buckshot tires. they make a 36" that is very narrow. Price is reasonable too.
    Kent
    1989 K5
