35'S WITH 3:73 RUNNING GEAR?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WELLH2O, Apr 2, 2001.
  1. WELLH2O
    WELLH2O Registered Member
    34
    Ohio
    35\'S WITH 3:73 RUNNING GEAR?
    That is the question that I would like answered I want to do a 4 inch lift and hack out some of the front fenders to run 35's is my new tranny and running gear going to like this or should I scrap the idea.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 35\'S WITH 3:73 RUNNING GEAR?
    I would go with the 6" lift for better clearance. This is if you do flexing or hard playing. If you are a street driver, then the 4" will be ok.
  3. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    I just put 35's on with a 4" lift. It's borderline. I ordered the 33's for the 4" lift but the company got the order wrong. It took about a month to get the tires so I decided try the 35's, much happier, look great. Wish I had a 6" lift. Also running 3:73 but thinking about going to a 4:56, whats your opinion?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would go with 456's 4 35in tires unless you have a sm465 tranny then i would go with 373's or 411's
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm going 35's w/ 4.10's... is my daily driver so what some decent freewau mpg too... otherwise I'd go 4.56's...
    1987 Chevy K5 Blazer- 350 TBI
  6. Re: 35\'S WITH 3:73 RUNNING GEAR?
    4 inch, 35s, and 4.10s, cutting and desent flex
    i'm assuming you have a 700r and 208 combo. so you might be ok wheelin in low. where it'll getcha is on the highway with your trannie trying to use overdrive. i wish i had 4.56s or a big block
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Blue, that's a badass picture...
    <font color=orange>To see my rig...</font color=orange> <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  8. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Running 4" with 35" Dunlop Mudrovers (which are excellent) and i have never ever rubbed the tire. This might sound dumb but i think 4wheel parts sold me a 6" lift, i have alot on clearence on the front tires.
    [​IMG]<font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red>
  9. 90STYLE
    90STYLE Registered Member
    Mar 23, 2001
    31
    AZ
    My rig has 35 BFG style mud terrains on it and I have a Pro Comp 4" kit. I can tell you matter of factly....THEY RUB!!!! I took the sway bar off and now they really rub....Of coarse I am only speaking of when Im wheeling...For the street they never touch. My .02$ worth.....Go with a six inch easy ride style spring. And stick with the cheap Hydro shocks the nitro charged shocks are way stiff. Also, I have factory Quad shocks but am only running one on each side. rides great....Last thing...BUY THE ORD STEERING BRACE!!!! MUST HAVE!!!!! Best of luck!
  10. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Says his is a '90...so I'm thinking it's the NP241
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am running a 6"" superride(which is more like a 5") and 35x15.50's with 4.10's(th305/208)... With 3.73s you will be fine....
    But I would probably go to a 6" to clear the tires better.
    I used to run 35's with 3.08's! It wasn't bad, but when wheelin I used 4 lo almost always!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  12. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Ok Blue... West Coast guys... southerners... You're kill'n me here... I'm jealous... everytime you guys post a pics I just want to bang my head and the wall till I get my rocker panel done and paint... UGGGHHH!!!! [​IMG] Wish I knew someone to do body/paint work [​IMG] D@mn rustbelt...
  13. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I'm running the 4" with 35's, 3:73's, and a sm465. I wish I had another inch of lift. I've trimed the fenders and still rub. You can check my pics at http://coloradok5.com. Good luck.
