35s with a 4"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ross, Jun 22, 2001.
  1. Ross
    Ross Registered Member
    Apr 19, 2001
    75
    IL
    35s with a 4\"
    will 35 by 12.5 fit with a 4" lift fit.
    1986 white K5
  2. J.R.
    J.R. Guest
    Re: 35s with a 4\"
    they do on my 85. i run 35x12.5x16.5, they are fine for street driving but dont do any real off roading with it or they will chew up your fenders.
    BIG BLOCK MAN
    "MORE POWER"!!
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: 35s with a 4\"
    I have 32's with a 4" on my 85 (or will when I get the lift finished this weekend). If I want to go to 35's, should I add a body lift or can I just do some minor fender trimming? If body lift, how much? I prefer to do as little body lift as possible and only if I must.
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  4. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    Re: 35s with a 4\"
    I had 35 bfg on my 73 with 3in lift. I had to do some minor trimming of the front fenders, but nothing on the back. I never had them hit when I was offroad either.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: 35s with a 4\"
    I have 4" Tuff Country HD springs with Dana 60 (additional 1" lift) as well as ORD HD Shackles (1/4" lift?) and with 35" SSR's they didn't hit at all right after the lift.........however, you unhook the swap bar (with ORD disconnects) and FULL flex (such as on our club RTI ramp) and it sure as heck does hit now..............time for the air cutoff wheel!
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Re: 35s with a 4"
    35"s will fit a 4" lift. A little trimming goes a long way to keeping them from rubbing.
    Lift It, Lock It, LIVE IT!!!
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 35s with a 4\"
    My 85 K30 has 4" Skyjacker front and rear springs and 35" tires. There are no rubbing at all until I turn a corner in a dip then the driver side tire contacts the lower corner of the front fender. The passenger side does not touch at all.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 35s with a 4\" *DELETED* *DELETED*
    Post deleted by thatK30guy
  9. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    Re: 35s with a 4\"
    I gotta BDS lift 4" w/ ORD shackles running 35's... my springs haven't really broken in yet but so far I haven't had any rubbing...
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Re: 35s with a 4\"
    One of the Jersey guys (I think his username is walt88) has an '88 with 35's and 4" lift (front springs, rear ORD shackle flip), and when we went wheeling he didn't have any rubbing.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
  11. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 35s with a 4\"
    I had a 4" with 35" bfg's on my 1979 Jimmy and I had no rubbing, but I was running a narrower rim then what they call for so it depends on thr rims and back spacing.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 35s with a 4\"
    I've got a 4" Rancho and 35x12.50 BFG Mud Terrains and they've never rubbed. I don't do rock crawling or anything but I've had all 4 wheels off the ground and landed hard enough to nearly roll over and never had my tires rub. I don't understand how people say that they rub or they have to trim. I don't have to.
    I've never disconnected my swaybar as I have no reason to. I don't run rocks, I run mud, and articulation isn't all that important there.
    Tim
  13. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    Re: 35s with a 4"
    I have a 79 K5 w/35" and 4" lift no rubbing even with the sway bar unhooked but I'm still running the stock 8" wide wheels. just painted them black.
    whats a 4 letter word for farm wagon? (ford) [​IMG]
  14. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    Re: 35s with a 4\"
    No trim here yet. I've got the 4" Tuff Country lift and ORD shackle, 35" Procomp MT's on 8" rims. I have scraped the front fender a couple times while rock crawling but nothing major-no fender or tire damage. I haven't decided on trimming yet and I may put on a 1" body lift.
    Let The Sun Shine Down Upon My Face
    Topless 73
  15. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Re: 35s with a 4\"
    I have a rancho 4" lift, 3" body lift, no sway bar and i had to trim the front fenders and "modify" the rears. I run 35x12.5x15 bfg muds on 8" rims.
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 35s with a 4\"
    Depends on what kind of off-roading you do too. Mud is one thing. On the rocks you guys really flex them up. Mine have never rubbed with the 4".
    Tim
  17. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Re: 35s with a 4\"
    If it flexes at all 35s & a 4" lift will rub. My fenders are trimmed a couple of inches and mine will rub even with the sway bar hooked up. This is with a Skyjacker 4", BFG MT 35x12.50-15 on stock raleys. Hell, 33s will rub with a 4" if the truck flexes good.
    Jim '80 GMC
    Freedom First!
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 35s with a 4\"
    You're crazy. Mine have NEVER hit the fenders. ABSOLUTELY NEVER. And I beat the @$#%@# out of my truck in the mud. I still can't understand how people say theirs have rubbed.
    Tim
  19. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Re: 35s with a 4\"
    I agree with 88 K10. My 35"s have never rubbed on my 4". I have flexed it up beat it no rubbing?? My lift is the Genuine from 4wpw.
    <font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red>
  20. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Re: 35s with a 4\"
    Just wondering if all yaers of blazers have the same fender well openings. I thought 72 an before were wider than 73 and after. I know that the side marker changed at some point. What about other demensions over the years?
    This may account for some of the differences in peoples ability to run tire size.
    Does backspacing or other rim demensions have an effect?
    Well now that I have had my thought for the day now I can stop thinking!
    Kent
    1989 K5
