35x12.5 on stock 1989 aluminum wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ladieslovemyK5, Jun 14, 2001.
  1. ladieslovemyK5
    ladieslovemyK5 Newbie
    Jun 7, 2001
    hey guys, i need to know if i can safely run a 35x12.50 r 15 on my stock 1989 rims. (alum, NOT rally) if you could help me out id really appreciate it.
    also, the blazer will have a 6in BDS lift, will the tires rub a lot? any other side effects?
    thanx again
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If I am right those are 7 inch rims. People have done it but I wouldn't recommend it.........Dan
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    they will fit, but it will pull the side walls in and "push" the center of the tread out. These tires will be better on a 10" rim. Generally you want the tread width and the rim width to be approx the same. This size tire has approx 10" tread width.(depending on maker)
    your right. I don't understand the jeep thing!
