36 inch IROKS with 10 bolts, will the axel's survive?
Discussion in 'The Garage' started by badassblazer03, May 18, 2004.
  1. badassblazer03
    badassblazer03 Registered Member
    Oct 2, 2003
    82
    Amherst, NH 03031
    36 inch IROKS with 10 bolts, will the axel\'s survive?
    I want to get a 4 inch lift and get the ORD 1 inch body lift and was wondering if first of all 36's will fit and if the 10 bolts can handle them?
    -Stew
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: 36 inch IROKS with 10 bolts, will the axel\'s survive?
    the front will if your light on the gas and keep it open but for the rear get a 14bolt
  3. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    I have a 4" lift 36" TSL 10b front & 12b rear. They will survive if you don't play hard, but if your like me you will get a 14 bolt... /forums/images/graemlins/laugh.gif
    Here the pic
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Rear will break, go with something a little more heavy duty like a 9" or 14 bolt SF
    The front will survive no problem unless you drive like a complete dumb ass. I run 36" Iroks on a LOCKED 10 bolt front and run my truck very hard on the rocks and have NEVER broke it.
  5. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I would get at least a 12 bolt rear, but if you are light on the gas, they will be fine. I have 10b in front with 37"MT/R's and I carry a set of axles, but have never had a problem. But once again, I don't hammer down on the skinny pedal. Just use your head and it will last.
  6. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    theres no difference in strength between a 12 and a 10 bolt and replacing a 10 bolt w/ a 12 bolt would be just plain retarted
  7. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    [/ QUOTE ].
    Ditto....
    Don't waste your money...
  8. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    To both of you, I disagree, but a) I'm not going to hyjack this post to say the same thing that has been said a million times in others, and b) Isn't it great that we all have our own opinion.
  9. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    the question is when it is time to go up with all the other rigs are you gona say ... sorry guys cant go up might break someting.... i cant. go ahead and get them, but plan on upgrading when your axel pukes. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  10. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    Im planing on putting a 14bolt in the rear, but for now i dont have the cash flow to convert the entire rig over to 8 lug. for now im sticking to the 10 in the back with a lockright igot of ebay. Im going to be running 35" claws. My question is can i fit a 15" rim on a 14bolt i know the drums are huge. Just desiding if if should go 16" rim or not.
  11. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Its not the rear axle that is a problem with 15" rims, only the front calipers on a 3/4 or 1 ton front axle. There it may take a little grinding to fit a 15" rim but they can fit.
  12. jekquistk5
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    Awesome thanks im purchasing tires here within the next week, so i wanted to know if i should buy the 35x16 or 35x15 but i guess ill go with the 15 if all that is needed down the road is some grindage! Ill put a pic up when shes finished
  13. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    15" wheels will clear those big drums on the 14bff.
    That's where I'm headed.
    Gotta do some grinding on the front, though (for the 4"+ backspacing wheels)
    I've read that the 2.75" backspacing 8 lug 15" fronts will not need any grinding at all. (but they stick out a bit)
    -T
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    What tire are you buying that is a 35x16 or 15? Has the MT claw recieved new sizes?
    Currently running 35x16 boggers and would like to find a wide 35 that would fit on my 14's and not wear like a swamper.
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    -Stew
    THey probably won't clear without some trimming, if you don't want to trim than I would get a 3" body or a 6" lift and 1" body.
    I honestly would say you wont break anything because those 36's are narrow. How much power do you have? motor stock? Stay away from the rocks and very deep mud and I bet you will never break anything. I never broke my 10B's with 33x14.50 tires and my built 406 pushing. I still have yet to have a prob with my front 8 lug 10B with 35x16 boggers on it and the same motor. I would say the 35x16 bogger would be meaner on parts than a 36x13.50 IROK with the same weight rim. /forums/images/graemlins/thinking.gif
