36 inch tires with 3;07 gears *DELETED*
Discussion in 'The Garage' started by 4x4k20, May 2, 2002.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    Post deleted by 4x4k20
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: 36 inch tires with 3;07 gears
    When I bought my '70 it had 3.08 gears with 12.50X15 33" and sb350/ T350. It was a dog with 33" and 3.08s.
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I had 3:08 and 33's for a while after I bought my truck also.....it couldn't hardly get out of it's own way.......with 36's I'd like 4:56.......I run 33's and 4:10 now....(700R)
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    That's nothing. I ran 35" on my '84 Blazer and it had stock 2.73 gearing!! /forums/images/icons/tongue.gif /forums/images/icons/laugh.gif
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I had 33's and 3.07's for 2 years... Im gonna go 35's and 3.73 real soon.
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I am not sure exactly what gear is in my rear, but by the tire size and what the tach reads at 60 I should have 3.07 or.08 and 38s. /forums/images/icons/shocked.gif I have 4.88s sitting in the box waiting to go in.
    The reason I dont know the rear gear is because I bought "a Blazer in a box". The front is the orig. stock 3.73 but the rear is unknown, till I pull them to put in the 4.88s.
    It lacks on the bottom end but not terribly bad, its drivable, but I dont have a stock motor either.
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    damn, and I thought i was bad at 38's and 4.10s.
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I just put a set of 36" Cepeks on my '75 Blazer with 3.07's. With low tread 33's on it before, the Blazer acually did fairly well as far as power goes. With the 36's, I couldnt spin the tires at all in High range, and could barely spin them in low (and they have only 20% tread).
    Last weekend, after trying to go up a small muddy grade and failing, I could barely get it to pull itself out over a rut and back onto solid ground on the flat.
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I cruise right along at 60 @ about 2000 RPM. I think. I have never been sure how fast I was going, just guessing and staying at pace w/ traffic which normally ran 60-70 on that stretch. I havent driven PI since early Jan so I am not positive on the RPM, but I am thinking it was right at 2000. Ive taken it out and played w/ it but havent really driven it.
  10. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Yep, I had 35x12.50's with 2.73 gears for a little while. It was terrible. I think that's what sent my transmission on its way out.
  11. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i used to have 3.07 gears and 36's, i run in hi until i got to town, 7 miles out, and then in town i switched to lo, that way i could get out of peoples way and get around town, until one day i decided to leave it in lo on the way home, crank broke in half, it wasn't pretty
  12. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I am running 36"ers with 4:10s and don't like it.Needs more power.With 33"s it was fine.My buddy ran 34"ers on a Chevy shortbed and had to use low in the 4 speed to get it rolling.I would recomend swapping gears or running smaller tires.You will be happier all around.
  13. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I'm running 4.56's with my 36's and a th350. You'll burn up your tranny if you run those 3.07's with 36's very long. /forums/images/icons/frown.gif
  14. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well i monly 16 so im not understandin this a lthat much lolo..but the way i understand it..the bigger tires..the bigger ratio of gears you want or something?..and HP..(engine)
    Bryan-later
  15. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Here you go
    http://www.4lo.com/
    Just plug in the numbers you have/want and it'll give you the ratio you'll need.
    Like, enter in your desired tire diameter, desired rpm at the desired speed, enter in the t-case ratio (click it to get a list of the ratios with the t-case you have..same thing with the transmission) and it'll tell ya what you need.
    At 70, you want to be at least at 2300 rpm (IMO). The higher the rpm at the speed, the lower your gears will need to be which will give you more low end grunt. A higher gear will give you better fuel economy up to a point. Does that help?
  16. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    On this page is a real simple to read chart. I prefer to use the chart personally, its easier to just look at and go across. The site also has some decent info on steering and suspension.
    http://www.superlift.com/gear.htm I linked you straight to the gear chart but you can navigate from any page on the site.
  17. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Oh BTW....Why did the original post get deleted?
  18. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    i just thought it would not get any more responces and i have decided to go with some 8lug running gear
  19. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Oh Ok. I was just wondering. Normally a post doesnt get deleted unless it gets ugly. LOL!
  20. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    k..i think i get it a little better now..so you would like adjust the rpm to match wiht your gears?
    Bryan- p.s- the link does not wrok /forums/images/icons/frown.gif
