36'' swampers on hummer rims
Discussion in 'The Garage' started by FlatBlackBurb, Apr 16, 2007.
  1. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    okay so i just picked up these beasts today
    http://sfbay.craigslist.org/pen/pts/312369897.html
    and a quick search on ck5 reveals stuff about centering and run-flats.
    okay so what are run flats? can i just stick these rims on my burb without any trouble at all or is it gonna mess things up. i dont run on the highway.
    thanks
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    What axle are you running first off?
    Second, when i tried putting unmodified h1's on my blazer with a dana 60, the stock tie rod location keeps the rim from mounting on the hub correctly being the rims have such deep backspacing(7"). Some have left these unmodified and used a 2" spacer to miss the tie rod location. Some also use a Dual Rear Wheel(dually) front axle and unmodified rims and this puts the tires at about what normal wheels would run.
    Most people recenter the h1's, which is removal of the inner center that mounts to the hub, and replacing it with a new center from USA6x6, Stazworks, many different companies depending on what style center you want. The new center is then welded in place of the old one. The new center allows you to have less backspacing, 3.5" is the normal for recentered h1's.
    The run flat is inside the tire rim assembly. Its a 2peice magnesium hunk of metal that pushes the bead of the tire against the rim, locking it in place and unable to become unseated. Alot of people cut the "mohawk" off to allow more room for the tire to contour to rocks or air down lower and not hit the magnesium runflat when aired down.
    I hope thats a good run down of it all.
  3. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    when you cut the run flat portion off the bead lock ring.........don't set it on fire.
    you really don't want any part of a magnesium fire :doah:
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Actually, I tried lighting my shavings in a propane flame, and they didn't even come close to trying to ignite. They just turned red, and curled up.
    Like I've said before, if there is any mag in there.. it's such a small amount that it's not worth mentioning. Either they "used" to be made of mag at first, and I have something newer.. or someone just assumed they were mag.
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    not sure.......when I got my set each set of run flats still had the official looking sealed bag of grease taped to it. so when actually driveing on the runflat. they didn't ignite.......or so I assumed.
  6. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    i heard of some guy who lit a hunk of magnesium on fire, and tried to put it out with water. then it exploded. left a black mark on a 50 foot cieling or something like that and singed his eyebrows completely off.
    im running 3/4 ton gear. ill try and fit them on there, but is it worth all the hassle of getting them to fit (if they dont), or should i just stick my current rims in there
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    A magnesium fire is a pretty intense fire. It will last quite some time, extremly hot, and DO NOT STARE AT IT! You will severly damage your eyes like you wouldnt beleive.
  8. 1990k5fan
    1990k5fan 1/2 ton status
    Jul 7, 2006
    217
    Gilroy, CA
    Ah I tried to get those tires / rims but the guy never answered back my emails :[
  9. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    oh i guess i just got lucky. i saw the ad after it was posted for like 10 minutes and called him up and went over there in a couple hours. he had a pretty sick old school hummer that he`was ranting about it cost like 40k or something
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they wont fit on there stock, so ull have to run spacers or get them recentered
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Post up some pics. Not trying to be a dick but the one rim I can see in the photo is not a beadlock rim. It does appear to be a factory civi H1 spare wheel though.
    Either way for $250 the tires alone are a deal:D
    Ira
  12. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    well are the rims even that great? or should i just take em off and stick my burb rims in there
  13. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    yeah ill get some pics. i got home when it was dark and dont have that great of a camera. ill get some pics when i get back today.
  14. sandawgk5
    Oct 28, 2003
    6,881
    If they are the 2 piece beadlock H1 rims then they are very nice and I would not change them out. If they are regular rims I would put the tires on some other rims that you have and avoid the hassles of the huge backspacing.
    Ira
  15. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    it doesnt really look like their beadlock... let me go out and grab a couple pictures of them
  16. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, I'd like to see a better pic too. In that one pic, the back spacing looks like it might be ok. But, it's hard to tell. I saw some nice hutchingson H1 beadlock wheels on ebay once, but it was only a pair, not 4 .. and they looked like they had back spacing that would have worked as is. Maybe that's something like what you have.
  17. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Here is the pair I found on ebay once. I wanted to snag them, but I never could find another pair to go with them. I searched the net with no luck, at least at that time. Looking at the BS, thease look like they could work as is.
  18. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    Haha I wonder who you heard that from:rolleyes: :haha: . He was welding it actually:doah:
  19. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    hey guys i just got home and uploaded some pics of them
    whatdya think. is it worth it to backspace? or should i just swap them with my burb rims
  20. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Just looking at them they appear to have too much back spacing, but it's hard to tell from the pic. But like I said, it looks like too much. They also don't look to be any type of two piece beadlock, they look like some plain wheels, and not worth messing with.
