366 Big Block...
Discussion in 'The Garage' started by 1985K20, Jan 31, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Does anyone know what is the torque and horspower ratings for the GM 366 (school bus type)? A friend of mine's got one in his truck and always wanted to know.:confused:
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    366's are garbage. Don't waste any time/money building one.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    That's not what he asked, is it?
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    How is this relavent to the price of rice in china?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    not going ot be only one answer for this, this engine was made for a long time and there will be many different torque and HP rated ones depending on year make model application and so forth, just liek with any other engine,
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I can check my 70 chassis manual this evening, ironicly I'm looking to purchase a 1970 C50 dump truck with a 366. If I remember correctly HP/TQ is 255/350 or something similar.
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    they arent junk!!
    I dont think the 366 is a "junk" motor--granted,its not a 427 or a 454,but it is a very durable and rugged motor,it has the tall deck and 4 ring pistons--from what I've read they can be bored 1/8 over to increase cubic inches...many parts are not the same as the passenger car and light truck big blocks,but many are interchangeable too..They are not noted for high power or torque,but they do last a long time..
    I dont have any specs for horsepower or torque,but I'd say they are about the same as a stock 350 4 bbl motor--not a ball of fire,but they get the job done ok...:crazy:
  8. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have a 427 Tall deck that came out of a 1985 GMC 6000. in my blazer and I love it I got about 13 MPG in it. It has a lot of TQ I guess it to be about 450 HP and 500- 550 TQ.
  9. BlueBlazer
    Feb 15, 2001
    1,940
    Is it stock? If so, are you nuts? I would be surprised if its over 250 hp.
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    no not 100% stock. One of the big things that I belive ruens the motor is all the limiters and such that was install in the motors.
  11. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    In 1970:
    From my 1970 chassis manual: 235 @4000 and 345@2600 (hp/tq)
    Motor was optional on 50 series and standard on 60 series trucks. The 427 was opt on 60 series .
  12. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    thanks y'all for you info, i appreciate!:)
  13. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    The 427 talldeck and the 366 talldeck are 2 different animals. The 427 can be built to the hilt for the right price... the 366 is a boat anchor.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is all anybody needs to know about a 366.
  15. dyeager535
    26,980
    Those are also going to be gross ratings, knock 20% off for net, which is how things have been measured for quite awhile.
  16. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    I guess if I had one, that ran, I would run it. But not if I had to build anything. Might get good gasmileage. 350 ft lbs of tork is pretty good for a stock motor. Would headers fit? tall deck, I'd think it might get screwed up.
  17. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I'd run one!
    I would not mind having a 366 under the hood--like I said,its a rugged,long lasting motor,not a powerhouse!!--they are REAL dawgs in stock form,many of the C-60 trucks and busses have govenors on them to limit top speed and RPM's,so they are rather anemic--but you can wake one right up by installing a better cam and carb,and it would most likely outlast the truck its bolted too--the best part is it LOOKS just like the other big blocks,the bling factor alone is a plus!--
    While we would ALL rather have a 427 or 454,or even a 396 or 402,the 366 is not just a throwaway motor by any means--they use the 366 in the trucks and industrial applications that would kill most of the other motors quickly...it would make a good work truck motor for a 1 ton flatbed or plow truck.....and there is a lot more 366's in the yards in busses and big "C" series trucks than any other size big block,so its about the last big block chevy you can buy reasonable anymore...:crazy:
  18. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I ran one in a 75 K5 of mine as a temp motor and ended up keeping it. Its not a ball of fire like said before but it has a good torque feel to it its not a high revver at all very very low rpms and your at the top of your power band. They are good cheap big block power to build because most people just give them away, mine was free out of a 73 2 ton pump truck.
  19. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    The 366 motor was designed to be a long lasting industrial powerplant, with a larger bore, but smaller stroke than a SBC 350. The short stroke kept the friction down, allowing these motors to last upwards of 300,000 miles, with little/no rework on them. ( At least I think it's the 366 that is built that way... could be confusing for an old GMC V6)
  20. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    My buddy just loves the 366 and 427 truck BBC's. They make for a nice hual to the scrap yard.
    As far as the 366 being the last reasonable priced BBC, I dunno about that around here 454's can be had for pretty cheap nowdays.
    As for myself I can see logical reason to drop a 366 in a rig. Free or not.
